intake coupler replacement
Old Aug 6, 2007 | 03:11 PM
finally_got_it's Avatar
finally_got_it
Default intake coupler replacement
the intake coupler that runs to my tb is torn at the flange..i was thinking about replacing with the power coupler that corvette central sells..is anyone else running those or is going back w/ ribbed coupler better?
Old Aug 6, 2007 | 03:57 PM
engle1147's Avatar
engle1147
Default Turbulent Question
I don't think it really matters much I run the "old school" OEM one - I mean how much turbulence could it create?
Check the cost of each - if there close get the power coupler thingy and you can add one more item to you mods list.
Old Aug 6, 2007 | 04:02 PM
MarkBychowski's Avatar
MarkBychowski
I've seen some posts here about using a rubber plumbing connector for hose between the TB and MAF. If memory serves you should be able to find out the specifics on what one to buy by doing a search on "home depot" in C4 tech.
Old Aug 6, 2007 | 05:41 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
The stock coupler is of an "accordian" style so that it is more flexible.
It is connecting a rigid, stationary part (the air filter housing, which is bolted solidly to the chassis) to a moving part (the engine, which can move on its mounts).
There is a reason the flexibility is desired and, if the smooth coupler gives no benefit...and it doesn't, other than mod list addition...then why would it be a good choice?
Feel free to put the smooth coupler in the same catagory as the airfoil, the TB bypass, the throttle advancer, and the temp sender relocater.
Larry
code5coupe
__________
not easily impressed....
Old Aug 6, 2007 | 05:56 PM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I've got the "power couplers" on my 95, just for the look. If you want the stock ones send me a PM.
Old Aug 6, 2007 | 07:45 PM
finally_got_it
pm sent
Old Aug 6, 2007 | 08:17 PM
davidnclearlaketx's Avatar
davidnclearlaketx
This place has lots of things you can use. Couplers, stainless parts, etc..
http://www.siliconeintakes.com/index...b56db8e15c525b
Old Aug 7, 2007 | 08:12 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
a 4" to 3" rubber reducer from home depot's PVC pipe section fits perfectly on the early C4's
I have my TB-->rubber reducer-->MAF-->Filter stuck directly on MAF.
Old Aug 7, 2007 | 08:15 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
All I can add to this thread is that's it's easier'n shet to cut your fingers while installing/removing those darned things. Those screw clamps that hold the coupler in place have some seriously sharp edges to 'em!
Old Aug 7, 2007 | 02:28 PM
NCBLACKC4's Avatar
NCBLACKC4
i think on the lt1 you can get the tb to the maf, but not the maf to the air filter. i looked at them at home depot.
To intake coupler replacement
