Buying shortblock, what else is needed?
Okay, if I buy or have a shortblock assembled for me, what else will I need? I am already have the intake and exhaust. I was thinking of the...
heads
cam and lifters
roller rockers
oil pan and pump
distributor
plugs and wires
I know I'm forgetting lots, that's why I come here.
CarPushrods
Gaskets,head,oilpan,intake,etc
waterpump
Bolts,waterpump ,valvecover,head,oilpan,washers,etc
valvecovers
oil filter,coolent
Hoses,clamps
Belts
coil
Throttlebody
Oil pump bolt,oil filter.
Timiing chain and gears if it is a short short block
Timing cover,bolts
Fuel filter,air filter
gasket sealent
A2 gasket cement from permitex
Thermastat
Motor mounts
trans mount
vaccum lines
I know their is more but I am tired I almost have this engine together
I have a SR that I'll be using. And most of the other stuff.
Basically my motor is shot and I am replacing it with a shortblock and re-using my SR buying AFR 195's.
Basically everything outside the engine is taken care of. Just need to know the internals.
I already figured on gaskets, fluids and such. I realized pushrods, valve covers, waterpump (it needs replacing) and timing chain.
Question about timing chain. Should I go gear driven or are they too noisy?
but they only last about 20k mile.If you can find it in your budget, I would go with a belt drive and cover,if you can afford to have it fitted to the block
If you stil have the original balancer on the car the rubber between the 2 pieces is most likely shot after all these years.I would also consider if you are going to race it ,you need an SFI balancer,I would get the fluid one it doesn't have an expiration date on it
