Vacuum question.
Old Aug 8, 2007 | 09:14 PM
pack24's Avatar
pack24
Default Vacuum question.
Does anyone have a good layout of all the vacuum lines for an 87? I have the Chiltons for the C4 but it skips the 85-89 vacuum diagrams.
I think i have a leak somewhere but I may also have one running the wrong way. The guy before me removed the vacuum canister and charcoal canister when he installed the Carb. How important are these and can I block this off for now or are they monitored and confusing the computer?
I also believe I have a leak because I can't get the timing to sit at the mark. Either 8btc or 8atc. As soon as I get near the 5 mark it either drops or rasies a bunch. This sound like vacuum or should I be looking elsewhere?
Old Aug 8, 2007 | 09:19 PM
86PACER's Avatar
86PACER
There is a vacuum diagram sticker on the radiator shroud, unless yours is missing.
Old Aug 8, 2007 | 09:20 PM
JackDidley's Avatar
JackDidley
Have you put the tpi back on ? If the computer is operating the ignition, did you unplug the esc wire when you set the timing ? You may get more help, if you give us some details.
Old Aug 8, 2007 | 09:25 PM
pack24's Avatar
pack24
Default TPI back on
TPI is now back on. The sticker there but only shows the engine circuits. All that is good except the vacuum canister and charcoal canister are gone. I did not disconnect the ESC. That's the 4 pin on the back side correct?
Old Aug 8, 2007 | 09:32 PM
86PACER's Avatar
86PACER
You need to, in order to keep the idle steady when setting timing. Read the emissions label on driver's side of radiator shroud, near upper radiator hose. Disconnect this one:
Try your timing again. Disconnect battery and recconnect EST after setting timing to clear code caused by unplugging EST.
Buy a used vacuum canister and charcoal canister from a corvette salvage yard, reconnect hoses, and you're done.
Old Aug 8, 2007 | 09:37 PM
pack24's Avatar
pack24
Default Didn't see that one.
Buy a used vacuum canister and charcoal canister from a corvette salvage yard, and you're done.
I did see a single plug behind the distributor when I was putting back together but couldn't find where it went to. Is it connected to the distributor or is it just near it? I may have to move some of the harnesses near the booster and dig a little deeper.
Old Aug 8, 2007 | 09:39 PM
JackDidley's Avatar
JackDidley
Look closer to the brake booster. Tan with a black stripe.
Old Aug 8, 2007 | 09:45 PM
JackDidley's Avatar
JackDidley
I have a few pics of the vac stuff on my 87. PM or post me your email and I will send some. I have some with the plenum off that may help.
Old Aug 8, 2007 | 09:47 PM
pack24's Avatar
pack24
Default Found it
I see it now. I try setting that in the morning.
Old Aug 9, 2007 | 04:36 PM
pack24's Avatar
pack24
Default Thanks again.
It's amazing what a couple of hours on the web can do if you ask the right people. Cars working great. I just need to pick up the few last missing pieces and she'll be done.
Old Aug 10, 2007 | 08:38 PM
89 Bob L's Avatar
89 Bob L
Just saw a "New: vacuum canister on E-Bay.
To Vacuum question.
