Digital dash question
Old Aug 9, 2007 | 09:05 PM
ps374's Avatar
ps374
Default Digital dash question
Just replaced the socket and bulb for my water temp Gauge. After all was reinstalled I turned the key and ALL bulbs lit up. Today when I went to drive the car I noticed that the numbers for the oil pressure disappeared.The trip meter works fine but the oil pressure shows nothing. When i shut off the car and turn the key ALL the guages light including the oil pressure. When I start the car the oil pressure starts to register until it hit 11 Pound's and then it goes blank and dark. Is this a circuit problem or a sender switch problem?
Old Aug 11, 2007 | 01:44 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default dash
what year car?
Old Aug 11, 2007 | 08:01 AM
ps374's Avatar
ps374
Originally Posted by coupeguy2001
what year car?
1984
Old Aug 11, 2007 | 11:50 AM
engle1147's Avatar
engle1147
Changing the sender would be easier than pulling the dash out again. The sender may have died.
Did the number leds for the pressure work without the back lighting before you installed the new bulb? If so - it sounds like the problem occured after you pulled the dash to change the bulb.... seems like problem may have been self inflicted. You may want to check to see that the connectors are fully seated and that no pins backed out of the connectors.
I've heard other forum members say that there is a connector on the firewall behind the battery which can get "gunk" / build up in the connectors and cause gage cluster problems...this may be worth a look.
Good luck!
To Digital dash question
