From: Life is just one big track event. Everything before and after is prep and warm-up and cool-down laps
Cruise-In III Veteran
Cruise-In IV Veteran
St. Jude Donor '12
Mine is somewhere between a 16 and 17MM flare and a 5/8 & 11/16 SAE.
As you can tell I tried to get mine off over the weekend. My 16MM didn't fit, my 17 fit but as I applied tourque to it it started to round the nut. So I tied my SAE open ends and nothing seemed to fit. I'll have to wait a few weeks until I can get it on a friends lift, drop the cat on that side and see if we can get that darned thing off
That's a new one on me, too. When I changed mine, I unscrewed the gas cap to de-pressurize the fuel in the tank.
Second, I pulled the fuel pump fuse.
Next, I started the engine and let it run until it ran out of fuel.
For safety's sake, I then disconnected the battery to negate the possibility of introducing a spark under there via accidentally contacting the knock sensor heat shield, the starter solenoid wiring, etc... with a wrench.
By the time I loosened the fuel line fitting, only about 1/4 of a cup of gasoline came out. I was easily able to manage the rest with a shop towel.
This thread reveals that the flare nut is supposed to be 16mm and the fuel filter nut is supposed to be 20 mm. Some good info in there too.
Okay, now I'm really scared that I'll start having a fuel leak. Was the '96 supposed to come with o-rings on the filter? How do I go about making sure the connection doesn't leak?
I put my health at risk by trying to change the filter with gas flowing out of the line at full flow. I had a catch can to capture the fuel as it fell out, and while I was fiddling with the flare nuts, some of the falling gasoline splashed out of the can and into my eyes. This forced me to take an hour-long-break while the can overflowed onto the ground, as I flushed out my eyes with water and called the poison control center for advice. After that I wore goggles and finally found something to cap off the fuel line.
I think the old one was the car's original fuel filter, because those flare nuts were practically welded in place. Some guys get lucky and their filter just spins right off, and they come in here and post that the job is easy, but that is not the case for everyone. One of the flare nuts got deformed a bit and the old fuel filter was completely misshapen by the time I got it off due to how much force was needed. Getting the new filter on was just as much of a pain because the flare nuts had to be just right to keep fuel from dripping out. My O-Rings were nowhere to be found but eventually I got the dripping to stop without them (does this mean it's sealed well enough?)
The whole time I was trying to tweak it to make it stop leaking, gasoline was soaking its way all down my arm and through my shoes into my feet. It burned like hell and I'm now covered in first degree burns. This was by far the most painful and traumatizing job I've done on the car, because I did it this way. So remember, the lesson is, do not try to swap the filter while the gas is siphoning, even if other people on here tell you that they did it successfully. You might not be able to do the swap nearly as quickly or easily as they did depending on the condition of your flare nuts and your accessibility, and in the meantime you will be getting a chemical burn. So put the car down, jack it up differently and try another angle.
ROTFLMAO...
Wow!
You got chemical burns from gasoline? Hrmm. Thats rather strange.
the L98 is easy to swap out. In and out in 20 mins maybe?
A rag around the end of the fuel line lasts long enough to soak up any gas (which just does a fast drip on our cars and doesnt run out like you experienced)
Even after all the sucky labor, its still more gratifying than paying someome else to do it IMO
i went to change the fuel filter. got underneath the car (parked in my garage) which was on jackstands, 1/4 tank gas, the fuel pump fuse pulled, the cap off to relieve any pressure, and when i got the connection off, gas poured all over me, by the time i could get out and back under with a container to collect the gas, it was pooled all over the place. i could just envision the car going up in flames and the house with it. Never again!
Is that a valve that opens and closes? You are a genius. Out of curiosity, why not put one on both ends?
Yes it is an open/close valve, you just put this into the Female end ofhte fiting when you pull the male fitting out, then put the other end of the fuel line going to the engine into the open end female end.
My car has braided fuel line so it is not a big deal.
Summit and Jegs have these in stock, they are a little pricey but well worth the money.
From: Beautiful Down Town "SWINDLEHURST" Long Island NY
This may sound ridiculous-ly stupid, but after pulling the pump fuse -- start / run till it stalls ---- then remove the 4 screws holding the gas hatch --- and pull the hose to the pump.
The lesson I learned from my install, put this onto the end of the fitting behind the Fuel Filter, works great Never a need to pay someone else!
I've been planning to throw one of those on to, with a washable filter, and run new line up to the rails. The hard lines on mine get in the way up top by the rails and it will be nice to not buy filters. I had a washable filter on a previous car and it was very nice. The shut off valve works wonders.
I have changed the filter on mine, it was not a problem. Some gas does come out but only very little before the threads seal. Leave a rag wrapped around the line.
From: No more yankee my wankee, the Donger is tired!
Originally Posted by Road Agent
Next time get an adult to help you.
Best statement in the thread.
But changing a fuel filter should not be a life changing experience.... unless you catch your *** on fire. If you have gas leaking out and you've capped off the line, put a pan down until it leaks all the fuel out of the line.
2016 C2 of Year
2015 C3 of Year Finalist
I just changed mine today and saw this thread. At least on the 85 you have to unplug the fuel pump relay on the driver's side firewall or it will run and pump gas when it sees the drop in fuel pressure, even with the key off.
LOL, are you serious? Why would it do this?
The 1996 definitely does not do that. Press the schraeder valve for a bit and all that pressure will be gone.
That is totally bogus. First, the fuel pump relay is 100% controlled by the ECM. When the ignition is first turned on, the ECM powers the fuel pump relay for 2 seconds. Then, only after the ECM receives pulses from the distributor, indicating that the engine is turning (cranking or running) does the ECM again power the fuel pump by closing the fuel pump relay. Nowhere is there a fuel pressure sensor. The fuel pump relay never "sees the drop in fuel pressure" with the key on, or "even with the key off". The same is true of the ECM. There is nothing on a C4 that reports fuel pressure, and nothing to receive or react to such input.
I finally found out why my new fuel filter has been leaking. Found an o-ring on the ground near where I've been working. Reluctantly, I decided to take the filter off again, but THIS time I pinched the fuel feed line on the fuel tank. Took two minutes, and what a difference! Only a few drops of gas came out after I loosened the filter. My wrenches also seemed to fit much better this time, or maybe it was just the fact that I wasn't freaking out because of fuel flowing down my arms. Overall it took about 20 minutes to take it off and put it back on this time, and it went beautifully, simply because I prepared this time.
After looking at the detached lines for a while I finally located the other O-ring, so I put the one that I found on the ground on a similar place on the other line and it sealed right up. I'm glad I got to experience this job from the perspective of those for whom it went really well.
Did mine in about 10 minutes, lost maybe a cup or so of fuel tops..
Jack the pass side up only (plese use stands), remove gas cap and goto town. Fuel should pool up on the DS of the tank so it doesnt siphon down to you. Having less than a half tank helps.
Make sure and get a wrench on the filter ends when loosening/tightening your lines so you dont twist/kink them or youll be hating life.
