Lessons learned during fuel filter change
Old Sep 1, 2007 | 07:10 PM
  #41
LouisvilleLT4's Avatar
LouisvilleLT4
Did mine in about 10 minutes, lost maybe a cup or so of fuel tops..
Jack the pass side up only (plese use stands), remove gas cap and goto town. Fuel should pool up on the DS of the tank so it doesnt siphon down to you. Having less than a half tank helps.
Make sure and get a wrench on the filter ends when loosening/tightening your lines so you dont twist/kink them or youll be hating life.
In my case, jacking up the passenger side did not prevent the siphoning. I blame the fact that I had a full tank of gas. The only way to be certain that this won't happen is to clamp the fuel lines at the tank, every time.
Old Sep 1, 2007 | 08:07 PM
  #42
SpinSirLT4's Avatar
SpinSirLT4
Originally Posted by Road Agent
Next time get an adult to help you.
Wow, guess I just got lucky doing mine. Threw it on the lift in the shop January '06, had the thing done it ten minutes without a problem or any real gas loss. Its been awhile, but dont really remember any complications with it. Its been about 7k miles since then, I'll probably put a new one on this winter(yes, Im that guy), not looking forward to it now after reading these war stories...
