air conditioning vents
Old Aug 16, 2007 | 08:28 PM
snowfun3's Avatar
snowfun3
Cruising
Default air conditioning vents
can anybody tell me why my air wont come out the dashboard vents on my 96, I cant seem to figure it out checked vacume lines and fuses. thinking maybe its the controls any help would be appreciated
Old Aug 16, 2007 | 09:29 PM
white96's Avatar
white96
I will after you run the ac for awhile, it starts out blowing on the floor and will slowly transfer to the dash vents, why it does that I have no clue.
Old Aug 16, 2007 | 10:13 PM
SunCr's Avatar
SunCr
From all the Posts concerning the '96, vacuum harness is loose at the Programmer. I thought it was a Tech Tip, but couldn't find it. You might try a Search but putting in "Programmer" seems to bring up nothing but tuning.
Old Aug 17, 2007 | 12:29 AM
pcolt94's Avatar
pcolt94
Have you looked at the plastic check valve under the plastic cover on the right side of the engine. It has 3 hoses to it and usually cracks or breaks up with time and temperature. Then not enough vacuum can be achieved to activate the vents properly. It is a pretty common occurrence and inexpensive to fix if you find it is defective. It may, or may not also affect cruse operation just depending on the amount of leakage.
Old Aug 18, 2007 | 10:55 AM
89 Bob L's Avatar
89 Bob L
It is either the 3-way check valve or the harness to the programmer. You should also check the vacuum lines to the check valve as well.
Old Aug 18, 2007 | 11:15 AM
Mark C5's Avatar
Mark C5
St. Jude Donor '08-'09-'10
It also could be the rubber nipples on the programmer collapsing under vacuum. Search the C4 General forum using "AC Vents" and you will get a lot of good info on your problem.
Old Aug 19, 2007 | 10:34 AM
snowfun3's Avatar
snowfun3
Cruising
thanks to all who replied with answers to my ac problem looks like the three way check valve and nipple is bad, going to order new tommorow Thanks again
To air conditioning vents
