idle issue 91 l98
Old Aug 19, 2007 | 10:15 PM
lushdrunk's Avatar
lushdrunk
Default idle issue 91 l98
I have an idle issue I need help on, My vette starts up fine and idles fine (even when warm) but after I drive it for a bit, i will go to stop and it will idle at anywhere from 1800-2200 rpm witch makes it hard to stop. but if I put it in neutral and tap the gas it will drop down to normal. it sounds like a sticking cable but its not. no vac leaks, no codes, any ideas?
thanks
Old Aug 19, 2007 | 10:50 PM
Yellow2015's Avatar
Yellow2015
What year? auto or standard? More info needed but a good place to start is with a complete throttle body and IAC cleaning.
Old Aug 20, 2007 | 12:51 AM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default high idle
I had that once.
I cleaned the engine with a high pressure washer, and it did that.
turns out that the throttle position sensor wasn't sealed from the factory, and water makes it do that.
water, steam, coolant leak, air conditioning condensation, washing the car, etc.
Old Aug 20, 2007 | 07:46 AM
ittybittyfds's Avatar
ittybittyfds
i have the same problem i replaced the TPS sensor with no luck
i actually have a appointment at a corvette shop next week to hopefully get it fixed
Old Aug 20, 2007 | 11:06 AM
onedef92's Avatar
onedef92
Cruise-In IV Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Have you removed and cleaned the throttle body and IAC (idle air control) motor pintle?
Old Aug 20, 2007 | 11:58 AM
CFI-EFI's Avatar
CFI-EFI
It sounds like the throttle shaft bores are worn the the pot metal TB casting. The throttle plates can become misaligned, hang up, and not close the first time. If you don't want to buy a new TB, you may be able to find someone that will bush and seal yours.
RACE ON!!!
Old Aug 20, 2007 | 06:37 PM
91quasarblue's Avatar
91quasarblue
Do you still have the stock injectors 89-91 supposed to not be to good according to this site and they were right my 91 did alot of wierd stuff 5 of 8 injectors were bad had them changed car runs like it just came off the showroom floor.Had all that kind of stuff you talked about I would check your injector function.
Old Aug 20, 2007 | 07:20 PM
ittybittyfds
i did clean the MAF and the Trottlebody
were is the IAC located
is the on the under side of the TB were the Vacume line goes to?
Old Aug 20, 2007 | 07:44 PM
dorney7's Avatar
dorney7
I had the same with my '91 with the L98 engine. Had to have all 8 replaced after learning 5 were bad. Complete tune up as well and the car runs great. Just curious...did you replace with ac delco or something else,. I used AC delco at 168.00 each !!!...I hope they improved them since production of 89-91. Thanks Kevin
To idle issue 91 l98
