head replacement for the L98
i would like to know what aluminum heads are a good factory replacement that will still allow me to use the Headers
i would also like to know how much horsepower you can put through the factory trans and drive shaft running the 3.08 gears
are the 3.08 gears a god street gear or would i benefit by replacing them as well
Both will break whenever they please. If the tranny has a cooler, it will last longer, but there is no guarantee.
You can use any head that has the "L98 angle", but a specific recommendation depends on what your goals are for the whole car. If you want a good stock replacement, I'd pick the Edelbrock Performer RPM heads.
The answer to the gear question is the same, what are the goals? Is this car going to keep the TPI-style intake?
