Porting the Heads
Old Aug 24, 2007 | 05:57 PM
96lastc4's Avatar
96lastc4
Default Porting the Heads
Hi
I was told if I take my heads off for any reason my car will start to burn oil. If this is true what can I do to make sure it does not happen?
Old Aug 24, 2007 | 06:06 PM
Aardwolf's Avatar
Aardwolf
Originally Posted by 96lastc4
Hi
How does porting the heads figure into this? Also who told you the car will burn oil? There are valve oil seals that you can replace if you are going to remove the valve train.
Old Aug 24, 2007 | 06:43 PM
CFI-EFI's Avatar
CFI-EFI
Leave them on? I was told the moon is made of green cheese. By what logic do you consider that a possibility? It sounds like it is time for some education, so you can do your own thinking.
RACE ON!!!
Old Aug 24, 2007 | 07:27 PM
InHot's Avatar
InHot
With the highest level of respect and humility I must inform you that the source of your information was in error and should be taken with a grain of salt as to mechanical issues regarding SBCs or any other internal combustion device in the future.
Respectfully submitted
Old Aug 24, 2007 | 10:12 PM
Curveit's Avatar
Curveit
example A example B
Old Aug 24, 2007 | 11:05 PM
96lastc4's Avatar
96lastc4
I want to have the heads removed and ported. However the mech. I used to used told me it would use oil if I removed them for any reason.
However it would seem he was wrong once again.
Thx eveyone
Old Aug 24, 2007 | 11:22 PM
STL94LT1's Avatar
STL94LT1
That makes no sense. Find a new mechanic.
Old Aug 25, 2007 | 12:39 AM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
You have I must say, a fine looking Vette. Find a better shop. Your engine will respond to skillfully done mods.
Old Aug 25, 2007 | 07:24 AM
BADDUCK's Avatar
BADDUCK
From: One day you're a Comet...the next day you're dust... Arkansas
Thx eveyone
He was covering his AZZ in advance!
Old Aug 25, 2007 | 08:29 AM
aboatguy's Avatar
aboatguy
Hi
who ever told you that is an ......
Old Aug 25, 2007 | 09:04 AM
redvette6spd's Avatar
redvette6spd
Hi
Keep any one the would say something like this at least 10' away your car and don't even consider opening up the shell if they are in eye shot Good God
Old Aug 25, 2007 | 10:06 AM
Muffin's Avatar
Muffin
The basic question has been answered now the real question.Why do you want to port the heads? Is this a part of a general upgrade including cam, intake, exhaust(long tube headers) custom cihp and tuning? If the answer to any of these questions is not yes then porting the heads wont gain you many,if any additional horsepower.
Old Aug 25, 2007 | 06:50 PM
96lastc4's Avatar
96lastc4
Hi
Yes I plan to put the hot cam and 1.6 rockers on the motor in the spring and with any luck longtube headers in a couple weeks.
What do you guys think of a 52mm throttle body as well to complete the package.
Old Aug 25, 2007 | 09:48 PM
redvette6spd
Hi
Though my car is a LT4 I have the mods you mention that you want. I did add a 52mm TB and the most noticeable thing was my throttle response it's difficult to say if any thing other than that occurred but I can most defiantly attest to a crisper snapper throttle response.
Your wanting to do a lot of stuff to your car make sure who ever dose the work knows what there doing get your self a plan/recipe for your needs or goals. Our cars have unique tuning software for 95&96 Vetts LT1 edit. I would suggest you add this to your list.
Old Aug 25, 2007 | 09:55 PM
redvette6spd
Hi
This should give you some food for thought some good stuff here http://www.wku.edu/~nathan.plemons/h...rformance.html
Old Aug 25, 2007 | 11:34 PM
96lastc4's Avatar
96lastc4
Thats a great link!!
Lots to ponder and I have thought about getting it reprogrammed after I finish the work.
Thx everyone
Old Aug 26, 2007 | 12:18 AM
thirdtimevetteowner's Avatar
thirdtimevetteowner
Determine the desired duration and choose a cam lobe that gives maximum lift for this duration without exceeding them maximum lift value. (excerpt from Nathan Plemons article)
Can someone please explain that sentence to me? How do you determine the desired duration? Simply by cylinder head efficiency?
Quench area? Compression ratio, naturally. Torque converter and rear axle gear ratio?
It is a wide open statement that, to me, confuses the issue. Any gurus want to chime in please?
I am planning a head and cam swap, after I install the EM headers I just ordered. I am still not sure what EM has to offer as to true duals size, and which mufflers I will run. I also have a TPiS mini-ram that will go on, probably after the head change. (although I have been told the mini-ram will change the characteristics of the stock cam, by advancing it to 10BTDC, instead of the factory setting (which is?) I may put it on at the time I install the headers and true duals.
Which brings up another question. I know there are L98 true duals out there, but on my '89 ragtop, I have to factor in the X-brace. I am thinking 2 & 1/2" from the headers back should fit w/out issues. Melrose makes a nice setup, using 3" around the tranny, into a 3" work of art X-pipe, then Random Tech hi-flow cats, and then it is reduced to 2 & 1/2". I seriously doubt those 3" pipes are going to fit between the floor and X-brace. I am looking for working examples if anyone wants to chime in. Thanks.
Rich K
To Porting the Heads
