Cant slow it down
Old Aug 24, 2007 | 07:13 PM
ps374's Avatar
ps374
Default Cant slow it down
OK here what I did so far with no results on the fast idle. I check according to the FSM the IAC motors and resistance is normal. I cleaned the IAc motors, I checked for juice to the IAC motors and all is good. I replaced the CTS sensor with the two prong type and checked the ground on the sensor and all is good. I checked the TPS sensor according to the FSM and all fuctions are normal both under throttle and off. I rechecked the manifold for leaks with WD40 and no change in idle. Car starts and idles at 2200 RPMs and drops down to 1900 when temp reaches 130. Stays at 1600 to 1900 when temp goes above 180 and stays at that RPM after temp reaches over 200.CHecked all bolts on throttle bodys and all linkage all is tight. WHat have I missed? (1984 with Xram manifold and 85 fuel pump with 8746 ECM) Car ran flawless for 9 months of ownership except for a spratic check engine light code 44 (lean ) and 13 (02 sensor).
Old Aug 24, 2007 | 07:51 PM
CFI-EFI's Avatar
CFI-EFI
You spent a lot of time checking the IACs and their workings. The quoted passage, above, is proof the IACs and the ECT sensor are working. I hope you tested that ECT sensor, before you threw it away.
The massive air leak into the engine. When that happens to my car, I just take the intake manifold off, pull the epoxy patch out of the bottom of the valley, and re-epoxy the resulting hole in the intake. How are your intake gaskets? Are any for that wonderful manifold, manifold to plenum, or plenum to lid, leaking?
RACE ON!!!
Old Aug 24, 2007 | 08:46 PM
ps374's Avatar
ps374
Nope, I did not test the good CTS I took out (because when I up pluged it the idle slowed down even though the car started to miss). I tested it after I bought the new one and it was good. Pretty bright right. I have not taken off the manifold plate in fear it will be in vain since this is NOT a stock 84 set up but the Xram set up. Its a 3 hour job I'm told to get the Xram off. Since I'm extra careful and label EVERYTHING its 4 to 5 for me.I have sprayed every place I could to find a leak if there is one.Other than the fast idle the car runs fantastic, no misses, pulls strong?? If I'm loosing all that vacuum wouldn't the car run crappy? Only code I ever get with this car is 44 lean and 13 02 sensor and that has been spratic since I have owned it these past 9 months. It has a 8746 ECM not the stock set up if that means anything?
Old Aug 24, 2007 | 10:36 PM
brian84's Avatar
brian84
this is probably a dumb question, but do you think a blade could be hung open partly on one of your throttle boddies? causing a fast idol ?
and could a worn throttle boddie be so badly worn it would cause that much extra air to pass thru it and make the computer add fuel to compensate for lean cond, even when there is no throttle imput thus causing a higher than normal idol speed?
just an idea - probly not the case tho.
Old Aug 25, 2007 | 07:44 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default code
getting a lean code means you have a vacuum leak or a bad oxygen sensor. but I'm with Brian, are you sure you don't have a throttle body cable going bad and keeping one of the throttle bodies open? That is probably the only way it will run that good, and keep those RPM's. by the way, don't put it in drive when it's running like that unless it's pointed AWAY from your other car and your house
Old Aug 25, 2007 | 08:47 PM
ps374's Avatar
ps374
They are closed tight. They were rebuilt by previous owner 3 years ago.The linkage is good and all external things seem to be working fine. The 02 sensor is about 6 months old.
Old Aug 25, 2007 | 08:54 PM
engle1147's Avatar
engle1147
On older TPI's you can adjust the position of the TPS sensor to a degree to compensate for high or lower idle conditions. Min is .45V - Max is .63Volts. What does your TPS voltage read in the closed position?
Old Aug 25, 2007 | 09:05 PM
CFI-EFI's Avatar
CFI-EFI
You still have a massive air (vacuum) leak.
RACE ON!!!
Old Aug 25, 2007 | 09:16 PM
engle1147's Avatar
engle1147
RACE ON!!!
There is a leak of some type if it is that high. Get a piece of hose and use it to listen for sucking noises on and around the intake.
Old Aug 26, 2007 | 04:02 AM
conv90's Avatar
conv90
Timing?
while idleing , try to turn the distributor clockwise to reduce total timing and then see if it reduce the idle.
Check the timing with a timing light.
-Beppe-
Old Aug 26, 2007 | 08:05 AM
ps374's Avatar
ps374
RACE ON!!!
Even though I can find it in about 6 to 10 days you will be able to say I told you so. Thats when I plan to start taking things apart if the few other ideas dont work.
Old Aug 26, 2007 | 08:10 AM
ps374's Avatar
ps374
Did that many times, I think the neighbors must think I lost my mind running around the motor with a 3 ft length of heater hose to my ear.The only thing Im finding is a slight whistle near the center of the intake and its NOT a sucking sound but a slight whistle.Sprayed it with WD 40 all over the area were I think I hear it with not even the slightest change is RPMs.
Old Aug 26, 2007 | 01:48 PM
CFI-EFI's Avatar
CFI-EFI
When you unplugged the ECT sensor, the ECM should have seen that as an engine with coolant at -40°. The ECM should have richened the mixture and raised the idle to the highest possible cold idle. Even with a massive vacuum leak, that It should not have lowered the idle speed.
Maybe there is something "up pluged" in your ECM conversion.
RACE ON!!!
Old Aug 26, 2007 | 06:15 PM
ps374's Avatar
ps374
RACE ON!!!
I just read your post and went out in the garage. I unpluged the CTS and started the car. The car idled at about 1000 RPms and ran VERY ruff like it was flooding. They I hooked back up the sensor while the car had the lower idle and the miss and with in several second the idle jumped up to 1700 RPMs and then I waited till temp got to 120 degrees and unplugged the sensor again and there was NO change in idle .It stayed at 1700 RPMs.Does what I said make any difference in your theory or do you think it a ECM problem or the dreaded leak ??
Old Aug 26, 2007 | 07:48 PM
CFI-EFI's Avatar
CFI-EFI
When you first started it up cold, unhooked, it was probably so rich (-40° F) that it couldn't idle as fast as should have, given all the air it was getting. When you plugged the ECT back in, the mixture leaned to something appropriate for the conditions, and the idle went back up. It also makes sense that there were no changes when you unplugged the ECT when warm. That would lead one to believe the ECT and the ECM are working properly. As a further confirmation, you could close the IACs, and for insurance block the idle air passages, and make note of the idle speed. My guess is that it will still idle at 1700 rpms, reinforcing my long distance diagnosis of a vacuum leak.
RACE ON!!!
Old Aug 26, 2007 | 08:34 PM
ps374's Avatar
ps374
RACE ON!!!
If I did it correctly as you said I went out side, plugged up the IAC air holes on the throttle bodies and the car as you stated idled the same at 1700 RPM as it had been doing. I then disconnected the plug to the IAC and it continued to idle at 1700 RPMs with the same holes pluged. So as of now I planning to start labor day weekend to find the hole and take it apart. I gave it my best shot and thanks for you input and advise, its much appreciated.
Old Aug 27, 2007 | 12:11 AM
coupeguy2001
Default throttle bodies
if the throttle bodies are closed, you are getting air from another source. plain and simple. engines can't raise the rpm without air.
On the early bosch systems, like volkswagen and porsche, they have a cold start valve that only adds air, and the computer / oxygen sensor compensates for the added air by adding fuel. hence, cold operation...add the air, it will feed the injectors.
Old May 23, 2009 | 09:19 PM
jhhegarty's Avatar
jhhegarty
4th Gear
Default ECU resets idle
I had this same problem. after I replaced the manifold gasket to solve a coolant leak, the idle was now at 2000 rpm. eventually, I read in my Haynes (I know...) manual that, after replacing or re-assembling the IAC, Idle Air Control valve, the ECU resets the idle speed the first time the car hits 35 mph. I slammed the car into gear and drove it up past 35. It did reset the idle down to about 700 rpm and its working fine now. 1984 C4 crossfire all stock. hope this helps someone.
To Cant slow it down
