95 LT1 running rich
Old Aug 26, 2007 | 12:36 PM
blaughlin85's Avatar
blaughlin85
2nd Gear
Default 95 LT1 running rich
I need some help here... I have a 95 LT1 and I have been running rich for about a month now. I just got a tune up, replaced plugs and wires, cleaned the air filter, replaced fuel filter, and my check engine light is still coming on... I had to park the vette because Im getting 10 mpg and I can't afford to drive it. If anybody has a clue what might be the deal here, I would much appreciate any advice
Thanks again
Brett
Old Aug 27, 2007 | 10:23 AM
TJANKOVS's Avatar
TJANKOVS
I had problems w/ my MAF resulting is the car running really rich. I got the LEAN codes from the car since it was dumping in all the fuel it could. Cleaned my MAF and all was well. Gotta be carefull of the oiled filters I guess.
Old Aug 27, 2007 | 02:58 PM
blaughlin85
2nd Gear
how do I get the LEAN codes? and how do I put it in? Im new to working on corvettes... Sorry to ask, but what is the MAF?
Old Aug 27, 2007 | 03:49 PM
STL94LT1's Avatar
STL94LT1
You need to find out what codes have been set. AutoZone will scan the codes for free.
Old Aug 28, 2007 | 02:03 AM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Thanks again
Brett
Reverify plug wires are on the right plugs. Its very easy to mess this up. If all you did was a tune up, then the tune up has a problem.
The check engine light may be due to rich condition caused by a misfire, which is very mild ona sequential injection of a stock engine.
Old Aug 28, 2007 | 06:11 PM
mikem350's Avatar
mikem350
Good luck getting ANYBODY to scan a '95 for free. They take a special cable and scanner. I searched "freescan" software and have been trouble getting it to work on my '95 Z28.
Anyway, get it scanned. Get the codes and post 'em back here
Old Aug 28, 2007 | 11:11 PM
95BLKVette's Avatar
95BLKVette
You don't need to do anything special to pull the DTC codes on a 95...I have one
Above your right knee under the dash is the ADL computer connector.
Counting top row left to right #1 is upper left, upper right is #8, the counting continues on the second row from left #9 to right #16.
All you have to is jumper ( a simple rebent paper clip is the tool of choice) #4 & #12 which are directly one over the other. Then turn on the ignition but do not start the car.
The speedometer display will spit out all the codes, module by module starting with module 1, then 4, 9, and A, ending with a 1.0 when done.
Write down what you see for each module and post it to us.
We have the service manuals that describe the problem in detail for each code and recommended troubleshooting.
BTW, all Vette owners should buy the service manuals for their vehicle available at the Helm website...the pair for the 95 are $120 + shipping and well worth the price.
Good luck
Old Sep 22, 2011 | 06:19 PM
flhx5241's Avatar
flhx5241
been having same trouble with my 95 with 128k miles, the ses light would come on and off had codes scanned read maf and both o2 sensors. my mechanic said maf would set off o2 codes he took maf off cleaned it rescanned and then read right bank o2 sensor....changed that and BAM...done the trick runs great idles smooth and im a very happy man...
Old Oct 2, 2011 | 09:08 PM
c4speed's Avatar
c4speed
From: Atco Raceway in between Pa & Nj 13.073 @ 106 MPH
AutoZone will not scan a 95, ask me how I know.
Old Oct 2, 2011 | 09:13 PM
STL94LT1's Avatar
STL94LT1
Four years ago they would.
Old Oct 3, 2011 | 08:17 AM
bjankuski's Avatar
bjankuski
If you are not getting a check engine light I would guess you have a failed O2 sensor.
Old Oct 3, 2011 | 07:06 PM
C4GUY's Avatar
C4GUY
Can you explain this a bit further for some education?? I have a code
H44, lean left 02, but get no check engine light either. I started checking to investigate a very occassional ping.
Not trying to hijack just curious between the correlation of no check engine light pointing to O2 sensor.
Thanks.
Old Oct 4, 2011 | 08:17 AM
bjankuski's Avatar
bjankuski
Thanks.
Over time the O2 sensors slowly fail and they can start to give incorrect readings to the computer. The readings may not fall out of the tolerance range that will set a check engine light but they can be far enough off to cause fueling issues with the car. Since you have set a code 44, at some time I would check for an exhaust leak, air system failure, bad injector, or failed O2 sensor. A O2 sensor error will turn the SES light back off if it starts to operate within the computers expected operating window but it may be pointing to a hidden problem.
Old Oct 4, 2011 | 10:02 AM
C4GUY's Avatar
C4GUY
Thank you for the clarification, helpful indeed.
Old Dec 16, 2011 | 12:24 PM
pcolt94's Avatar
pcolt94
If it's not OBD2 they can't scan it. Last I heard AZ has very limited capability for OBD1 and especially not for the 94 & 95 vetts.
Good luck
Learn how to use the on board diagnoistics. It's a feature that works great. It will tell you the codes in all the modules. Some code readers and scanners will only tell you information about the PCM (mod #4).
It sure sounds like the O2s might be giving a problem. Its a direct input on gas mileage. If the SES light is flashing, there is probably a code in there.
Old Dec 29, 2011 | 05:20 PM
Lyle Larson's Avatar
Lyle Larson
1st Gear
How do you know!
To 95 LT1 running rich
