coolent leak
Old Aug 31, 2007 | 03:25 PM
90SteelBlueCoupe's Avatar
90SteelBlueCoupe
Default coolent leak
ive got a coolent leak in the back of my motor. as soon as i poor into my reservoir it starts pouring out the back of the motor. just how screwed am i?
Old Aug 31, 2007 | 09:29 PM
engle1147's Avatar
engle1147
Not screwed at all.....just pull the engine or tranny and replace the freeze plugs in the back..... and your done.
Old Sep 1, 2007 | 04:53 PM
90SteelBlueCoupe
well it over heated too the temp gauge hit bout 280 F
could it still just be the freeze plugs?
Old Sep 1, 2007 | 07:32 PM
85 500 horse's Avatar
85 500 horse
If you lost enough coolant, that would explain the high temps. If it indeed hit 280, you could have damaged the heads, warped the block, etc.
Old Sep 1, 2007 | 07:43 PM
Da Mail Man's Avatar
Da Mail Man
Old Sep 3, 2007 | 02:58 PM
SunCr's Avatar
SunCr
Where at the back of the motor? The freeze plugs are on the sides of the Block. If it's coming out up top - towards the distributor, then you need a new intake manifold gasket. The temp you reached may have caused other damage - maybe not. You need to fix where it's leaking and then check compression. AND if it is a freeze plug, then it probably has enough galvanic corrosion to destroy the head gaskets so checking compression and/or doing a leakdown test isn't a bad idea.
Old Sep 3, 2007 | 03:37 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default water
Remember, there are 2 more freeze plugs at the back of the block just above the crankshaft.
I would not suspect those, though, I would go for the hoses towards the back of the block spraying the water. heater hoses, etc. hard to dislodge a freeze plug.........
If you have water out the back underneath, I also would suggest you look to see if yoiu have the factory water/oil cooler next to the oil filter.
Those hoses go unchanged for years until they either start to leak or burst.
Old Sep 3, 2007 | 03:52 PM
waupungk1's Avatar
waupungk1
headgasket? i was driving my car when the headgasket went out, and it leaked from the back of the motor.
Old Sep 4, 2007 | 09:08 AM
pcolt94's Avatar
pcolt94
I had a 90 Firebird and the same thing happened, pored out the back. Had to get it done fast as it was the wife’s car and had a shop do it. It was the freeze plugs on the rear of the engine.
Thought it was a really strange problem to happen in that location, it always bothered me. They had to pull the engine.
Old Sep 7, 2007 | 06:16 PM
90SteelBlueCoupe
well thanks for all the input guys ill see what all i can to do this this weekend. ill keep yall posted on the progress.
To coolent leak
