Wierd traction control problem
Old Sep 6, 2007 | 05:59 AM
93 ragtop's Avatar
93 ragtop
Default Wierd traction control problem
A few months ago, I purchased another 93 corvette, which is heavly modified with a turbocharger and a Accel DFI system. I have never driven the car yet, but I have noticed, while sitting still, running in nuetral, (6sd) when I try to rev the motor, the traction control engages and kicks the throttle back.
Also, the person I purchased the car from said he had noticed that one of the brakes would lock up sometimes.
Any ideas what would cause this?
Also, I purchased a 95 z-28 throttle cable to bypass the traction control box, and I was considering bypassing the ABS. Would this be as simple as running new brake lines, 1 to the front and 1 to the rear, then teeing to each wheel from there?
