Greetings, today I hit a mega pot hole and the rear end of the car noticeably "jumped" to the left after slamming into the hole. About 2 minutes later both the Sevice ASR and Service ABS warning lights came on. When starting up again the lights come on after driving for a couple minutes.
What need I do? Thanks, Larry
Also, what is INFL RST that appears when I start the car?
Just 2 thoughts for starters.
Check the fluid in the master. Make sure its very full at least to the line. If your down a lot, check for leeks and investigate.
Its possible the impacted shock to the car created a problem in one of the wheel speed sensors and the brake computer is seeing this as a problem. Also, check any electrical connectors associated with this.
