IAC-How do I know its good?
Old Sep 9, 2007 | 04:52 PM
Jinxie's Avatar
Jinxie
Default IAC-How do I know its good?
Hi
I was having a few issues with my 85. One of them was I couldnt get the rpm below 1100. I just purchased the car so I dont know the history.
Anyway, I set the idle speed and tps according to the method in this forum. I disconnected the IAC to start and set the idle to 450 rpm. I set the tps to .54V at idle. I started the car and since it was at operating temperature, it came down to a nice idle at 620rpm.
This morning I fired it up again cold. It wouldnt come down below 1100 rpm. I removed the throttle body and IAC and cleaned them, but how do I know the IAC is good? Maybe some other sensor is telling it to open? Why did it work good when I reset things last night?
Also, what is the proper procedure for cleaning the IAC? Is there any adjstments?
All help apreciated!!
Old Sep 9, 2007 | 05:14 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
As far as I know, you have to disassemble and clean or replace it. There's no way to tell for shure without looking at it. By the time you have it apart enough to look at it, may as well just replace it.
-Also, check your injectors. They should read 16-17 ohms.
Hope it's the IAC. Cheeper and easier.
Old Sep 9, 2007 | 06:05 PM
90convert's Avatar
90convert
Default ica
search the forum for ica there's some good info in past threads
Old Sep 9, 2007 | 07:50 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Remove IAC, push pintle all the way in by hand, measure the distance, then reinstall it.
Put car in diagnostic mode and turn key on 30 seconds. Feel the IAC, it should be vibrating. Turn car off, remove IAC. See if it extended
Old Sep 9, 2007 | 08:04 PM
jsup's Avatar
jsup
Again, if I'm going to do all that, I'll throw n a new part.
Old Sep 9, 2007 | 08:05 PM
RRT vette's Avatar
RRT vette
Old Sep 9, 2007 | 08:14 PM
Jinxie's Avatar
Jinxie
I know it vibrates because I had it diagnostic mode and couldnt figure out twhat the sound was. What does an IAC sell for roughly? I cant for the life of me push in the pintle by hand. Seems like I am going to bend the rod!
How does it work? Extended blocks off air passage? Retracted opens? Or opposite?
Thanx
Old Sep 9, 2007 | 08:15 PM
jsup's Avatar
jsup
Thanx
I got raped. I went to the dealer and it was over $100.
You can get an AC Delco one on line for about $40.
Old Sep 9, 2007 | 10:25 PM
CentralCoaster
That test takes about 15-20 minutes.
Or you can spend $35 and 30 minutes going to the parts store. Your choice.
Old Sep 9, 2007 | 10:37 PM
Dads90's Avatar
Dads90
AutoZone it was about 65.00. Apperently it wasn't the problem did'nt make a difference.
Old Sep 10, 2007 | 12:15 AM
Vito.A's Avatar
Vito.A
Make sure you do a thorough check for vacuum leaks?
Old Sep 10, 2007 | 08:41 AM
GIJoe's Avatar
GIJoe
St. Jude Donor '08-'09
I'm on my 3rd one. They are cheap enough to just replace
Of course both times, the thing was seized up too, so it was kind of obvious once I removed it.
Old Sep 10, 2007 | 09:04 AM
jsup's Avatar
jsup
And injectors.
Old Sep 10, 2007 | 09:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/agent86/IAC.pdf
Old Sep 10, 2007 | 03:53 PM
JAKE's Avatar
JAKE
Thanx
As you press on the pintel, you wiggle the pintel from side to side. It'll go in gradually.
In operation, as it extends, it closes off the air passage and as it retracts it does the opposite.
Jake
Old Sep 10, 2007 | 04:32 PM
jsup's Avatar
jsup
Did you use genuine Delco?
Old Sep 11, 2007 | 12:59 AM
samsonb's Avatar
samsonb
Is this the thing that makes a noise when I turn my 89 Vette off? I hear a whine or something for a few seconds, and then sound dies off.
To IAC-How do I know its good?
Old Sep 11, 2007 | 08:48 AM
opel's Avatar
opel
It's not uncommon for a 22 year old throttle body to leak air around the shaft.
Dave
Old Sep 12, 2007 | 10:20 PM
ramiles's Avatar
ramiles
Others outlined using diagnostic mode to test for full extension. Retraction can be checked by running and stopping and removing the key. Normal starting postion is 160 steps. You can even do this with the IAC removed (and powered). If you try to check extended with it removed you can shoot the pintle.
Old Sep 13, 2007 | 12:29 PM
Tom Piper's Avatar
Tom Piper
I don't know about earlier models, but on a '92 you can use a Vetronix Tech-1A scan-tool to command a higher idle rpm -- if the engine responds correctly, you know the IAC is ok.
The Vetronix scan-tools are "bi-directional", they send commmands in addition to reading the data like other scan-tools.
Tom Piper
