Blowing Gauges Fuse
Old Sep 9, 2007 | 10:17 PM
racers50's Avatar
racers50
Default Blowing Gauges Fuse
My 84 keeps blowing the fuse labeled gauges. My FSM is the new style with no electrical diagrams....I know the fuse goes to the O/D relay and I have unplugged it with no improvement.,...still blows....any ideas???
Old Sep 9, 2007 | 10:31 PM
jfb's Avatar
jfb
You have a lot of looking to do because the gages fuse powers a lot of stuff. Here is the list:
Heater ac control head.
LH and RH vanity mirror light.
Defogger control.
Vapor canister.
Courtesy light timer.
Overdrive relay.
Air select switching valve.
Header map light.
Low coolant module.
Cruise control brake switch.
Audio alarm module.
Tell tale assembly.
Air divert valve.
EGR valve.
Antilock control module.
This is from my 87 factory electrical service manual so some circuits may not be in an 84. I recommend finding out if there is a GM electrical diagnosis service manual supplement and if so, buy one.
Old Sep 9, 2007 | 10:51 PM
Da Mail Man's Avatar
Da Mail Man
Defogger control.
Vapor canister.
Overdrive relay.
Header map light.
Low coolant module.
Audio alarm module.
Tell tale assembly.
Air divert valve.
EGR valve.
Old Sep 10, 2007 | 04:26 AM
Ray Quayle's Avatar
Ray Quayle
- 1986 Original Owner -
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In VII Veteran
This is the kind of thing you'd get from the 1984 Corvette Electrical Troubleshooting Shop Manual Supplement ST-364-84-ETM:
Old Sep 10, 2007 | 04:47 AM
86PACER's Avatar
86PACER
The colored wiring diagrams of these shop manuals are worth the entire cost of the book alone. Compared to other make factory books, these are by far the easiest and clearest diagrams.
Old Sep 10, 2007 | 09:36 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Have a close look at the wires going into OD relay connector. The insulation may have shrunk back enough to allow a short. Unplugging the relay won't cure that.
Old Sep 10, 2007 | 10:11 AM
racers50's Avatar
racers50
Default Blowing Gauges fuse
Thanks for the great illustration....I should have mentioned that the fuse only blows intermittently. I did check the wiring to the OD relay and the insulator had shrunk but I taped the wires before I disconected it. Where is the best place to get the above referenced manual?? I checked Ecklers and mid America and they don't show it.....
Old Sep 10, 2007 | 05:53 PM
Ray Quayle's Avatar
Ray Quayle
Cruise-In I Veteran
Originally Posted by racers50
Thanks for the great illustration....Where is the best place to get the above referenced manual?? I checked Ecklers and mid America and they don't show it.....
Mid America number 600-101. This includes both the Shop Manual and the Electrical Supplement for $109.99. I suspect this reprint won't have the nice color schematics though.
You've got email switched off or I'd send it to you in PDF. 27MB in size though.
To Blowing Gauges Fuse
