How much do Gears cost?
Sep 10, 2007 | 02:10 PM
i want some 4.10's and im having a guy put them in for me as soon as i find some...how much should they run me?
Sep 10, 2007 | 06:29 PM
Sep 10, 2007 | 06:35 PM
this set at
www.summitracing.com looks like about $180 RMG-6902161
Sep 10, 2007 | 06:42 PM
check out ikerds, they are a supporting vendor
Sep 10, 2007 | 06:47 PM
Gears:
$425.00
http://www.mopartsracing.com/parts/viper.html
Install:
$150*
* If you pull the differential out yourself, the labor cost on most jobs is $150 (+ cost of needed parts) -Local shop in CA....
Additionals:
$125 - Speedo change (programmed or correction gears)
$15 - Gear lube
$15 - RTV "gasket"
Sep 10, 2007 | 07:31 PM
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
$400 for labor and rebuild kit if you remove diff yourself.
Gear costs depend on ratio and D36 vs D44. D36 gears are less common and more expensive. 3.07+ gears for 2 series cases cost even more.
Speedo correction = $10 for a new gear but will only correct within 10% of a 4.10. Exact correction requires a calibrator or aftermarket speedo gear, either is about $100.
94-96 automatics require reprogramming computer.
Sep 10, 2007 | 07:36 PM
I paid $300 for my Dana OEM 4.10 gearset, $350 for the turn-key install, and did the speedo reprogram myself.
Sep 10, 2007 | 09:18 PM
DTS did mine for ~$450 bagged-and-tagged.
Roughly $210 for a 4.11 R&P set for the stock 3-series carrier, $95 for the install kit, and $150 for the labor to setup the gears.
Make sure "a guy" has the tools & experience to do the job right.
