Drain hole on the rear diff...
Old Sep 12, 2007 | 08:56 AM
Nav Vet's Avatar
Nav Vet
Default Drain hole on the rear diff...
I just purchased a 91 coupe, and am in the process of changing ALL fluids (as recommended here).
Anyway, I removed a screw that is on the rear of the rear diff, but nothing came out??
The screw does not face the bottom of the unit, it faces the rear of the car, so if you laid down...the screw head would be facing you.
I assumed this was a drain plug, but after further research, I discovered that the rear diff has no drain plug.
I removed the fluid via the fill hole and put new fluid in.
Anyone know what the screw I have is for?
Old Sep 12, 2007 | 09:06 AM
Ruby6spd's Avatar
Ruby6spd
Active Streak: 90 Days
I believe you are talking about one of the bolts that holds the batwing to the pumpkin. Not something you want to remove if that is what it is.
Take a look at my sig - my diff is painted black but is what you removed on the bottom facing the back of the car? Is so it should be put back.
Old Sep 12, 2007 | 09:56 AM
Strick's Avatar
Strick
I just pumped out my dif yesterday and I think I got more on me than in the dif. There is a procedure to install a drain plug in our differentials, but I keep on loosing it. There is a kit you can buy from one of the catalogs that gives you a special drill with a stop and a template to locate the hole. I'm thinking I'll do this the next time I change out the lub. Oh, don't forget the limited slip additive. I used 1 1/2 bottles, I spilled the rest.
Old Sep 12, 2007 | 10:20 AM
Nav Vet's Avatar
Nav Vet
I think the bolt Ruby6Spd referrs to is the bolt I'm talking about.
I did put it back
Old Sep 12, 2007 | 10:33 AM
runner140*'s Avatar
runner140*
Go to www.c4guru.com then click "tech library" then click "drive train". Bogus has a step by step with pictures on how to change the diff lube.
Old Sep 12, 2007 | 12:59 PM
Strick's Avatar
Strick
Using this procedure I could only get 1 qt and maybe 5 oz out with that pump. Any body know the capacity of the diff? I couldn't find it in the Helms Manual. The GM rear axle lub came in 23 oz bottles. I only got about 40 oz in before it started coming out the plug hole. Oh, plus the 1 1/2 bottles of additive.
Old Sep 12, 2007 | 02:33 PM
Nav Vet's Avatar
Nav Vet
I pumped mine out also...not sure I got it all out though.
A book I have states 2 Qts, but I had about 1/4 of a quart left...but I
got in 2 bottles of additive.
Old Sep 12, 2007 | 03:31 PM
gslotman's Avatar
gslotman
52 ozs. – LT-1 Rear End = 1.7 quarts includes Posi additive
Old Sep 13, 2007 | 08:38 AM
Tom Piper's Avatar
Tom Piper
Is there a difference in volume between the D36 and D44?
Tom Piper
Old Sep 13, 2007 | 09:16 AM
Strick's Avatar
Strick
Iguess a drain plug is the only real way to get most of the lube out. Oh well, next time.
To Drain hole on the rear diff...
