4.00" bore
3.48" stroke
58 cc head chamber
.039" head gasket
Your going to have to find out the piston info, as in - volume or + volume, dish, flat dome.
You can assume the piston to be in the hole by about .025"
Are you using one of the free calculators on the web ??
just trying to find out as best I can. I have been using a calculator on the web but don't have all the information. http://www.csgnetwork.com/compcalc.html
The pistons are standard 1985 pistons - not sure as to the spec?
4.00" bore
3.48" stroke
58 cc head chamber
.039" head gasket
You don't need all that info if you are making changes to a stock engine. If it is a 1985, the iron heads are 76 cc. The stock head gasket is .021" compressed. The 1987 aluminum heads are 58 cc. It is easy enough to calculate the volume of the old head gasket. You can do the same for the new gasket, if it isn't listed in the specs for the gasket. Convert the bore and stroke dimensions from inches to centimeters and figure the swept volume in cc. The 1985 has a 9.0:1 compression ratio. With that information you can calculate the clearance volume, that is the sum of all the volumes above the piston, valve notches and all. Then alter the clearance volume to reflect the changes you are making. Reduce it by the (76 - 58 =) 18 cc difference in the heads and add in the additional volume of the 1010 gasket over the volume of the stock gasket. Then, with your new, altered, clearance volume, you can re-figure the compression ratio using the new parts you propose. Simple enough?
I'll HELP you with it. This requires no skills more advanced than grade school arithmetic; add, subtract, multiply, and divide. As I asked, previously, after I explained the whole process, "What part don't you understand?". Don't take this as in insult, I need to know what we are starting with. Do you know what compression ratio is?
well as long as the calcuators that I'm using are correct then yeah. I have input data to with my known information and some random information to creat the original known CR.
A change in both headgasket thickness and head CC's gave me the figure I quote.
These are the only two variables so I don't see how I can be going wrong.
