Pan Gasket Choice
Old Sep 22, 2007 | 11:06 PM
90Conv's Avatar
90Conv
Default Pan Gasket Choice
I need to replace my oil pan gasket. Which manufacturer makes the best gasket or are they all alike?
Thanks to all
Old Sep 23, 2007 | 12:51 AM
jsavoy's Avatar
jsavoy
FWIW, I used a 1-Piece, Rubber/ Steel Core Fel-Pro® Oil Pan Gasket (~$35). There are some multi-piece gaskets kits. I went w/ the 1-piece because I was afraid of leaks @ the corners of the pan.
Old Sep 23, 2007 | 02:24 AM
samsonb's Avatar
samsonb
I played it safe and bought a 1-piece oil pan gasket from the dealer for $60. I'd just get one from them, as that is a place you don't want leaks from.
I wouldn't cheap on an oil pan gasket.
Old Sep 23, 2007 | 11:40 AM
STL94LT1's Avatar
STL94LT1
Go with the Felpro, it is a bit thicker than the OEM.
Old Sep 23, 2007 | 06:57 PM
90Conv's Avatar
90Conv
Default Thanks
I will pick up the Felpro....Thanks for the info
Old Sep 23, 2007 | 11:22 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Felpro Not a single leak on any of my felpro gaskets (complete motor)
Old Sep 24, 2007 | 07:31 PM
JAKE's Avatar
JAKE
"That's the ticket, Laddie". Taken from one of the Star Trek movies.
Jake
Old Sep 24, 2007 | 11:08 PM
90Conv's Avatar
90Conv
I bought a gasket and started to take the car apart. I was wondering if it is recommended to apply some gasket sealant to the new gasket or install it dry. Does anybody have any experience both ways.
Old Sep 24, 2007 | 11:15 PM
STL94LT1's Avatar
STL94LT1
I installed mine dry, and no leaks (knock on wood) three years later.
Old Sep 25, 2007 | 01:15 AM
JAKE's Avatar
JAKE
You'll get differing views on this.
I follow the directions of the gasket manufacturer. The directions that came with my gasket said, in BIG BOLD LETTERS, not to use any sealer. That's what I did on the 388 I just build a few months ago.
I make sure that the block, oil pan, T/C cover, etc., are completely free of any trace of oil.
Years back when I used the older style four piece sets, I always used sealer - Permatex Silicone.
Jake
Old Sep 25, 2007 | 10:49 PM
90Conv's Avatar
90Conv
I bought the FelPro gasket and it came with two large O rings and two flat gaskets. Any clue as to what they are for?
Thanks Again
Old Sep 25, 2007 | 11:03 PM
STL94LT1's Avatar
STL94LT1
Thanks Again
They are for the oil filter adapter.
To Pan Gasket Choice
