Thermostat question
Old Sep 26, 2007 | 10:04 PM
jimkari's Avatar
jimkari
Default Thermostat question
I have a 93 that runs right around 200 degrees on the road. Over the weekend I completely flushed the entire system and pulled the radiator. There was a fair amount of leaves, dirt and even a small bird stuck on the radiator. I cleaned it all out. I then checked the thermostat in a pot of water and it does open around 180 to 185 degrees. However when the gauge reads 200 degrees the upper hose is hot and the lower is luke warm at best. I would have thought both hoses would be hot. I'm wondering if my 180 thermostat is really working properly. If the temp reads 200+ should both the upper and lower hose temps be the same?
Thanks,
Jim
Old Sep 26, 2007 | 10:36 PM
_twisted_'s Avatar
_twisted_
Before you cleaned the rad, that would be the case.
What you are seeing now is heat being exchanged ( heat exchanger = rad)
Old Sep 27, 2007 | 12:08 AM
jfb's Avatar
jfb
Hot coolant goes into the radiator, the radiator gets rid of some of the heat from the coolant, lowering its temperature and cooler coolant comes out of the radiator to go back into the engine to pick up some more heat.......that is why the upper hose is hot and the lower hose is warm.
Old Sep 27, 2007 | 06:29 AM
Da Mail Man's Avatar
Da Mail Man
Old Sep 27, 2007 | 06:40 AM
Tom Piper's Avatar
Tom Piper
Thanks,
Jim
Because the LT1/LT4 is reverse flow, what you are seeing is normal for a 180 degree thermostat.
With a 180 degree thermostat, open road temps for my '92 were about 194.
With a 160 degree thermostat, my open road temps are about 178 - 181.
Don't confuse reverse flow cooling with conventional flow.
Tom Piper
Old Sep 27, 2007 | 08:18 AM
jimkari's Avatar
jimkari
Thanks guys. I was wondering if the reverse flow was confusing me.
Jim
To Thermostat question
