LT1 383 Build
Old Oct 10, 2007 | 06:30 PM
billla's Avatar
billla
St. Jude Donor '14
Default LT1 383 Build
This engine is for my 1995 Impala SS, but I thought it'd be of interest to the C4 community since we share a common engine (mostly )
Power Target
  • 400 FWHP @ 5700 RPM
  • 400+FWTQ @ 2500 - 4500 RPM
Specs
  • 1995 LT1 (2-bolt mains)
  • Eagle 3.75 stroke cast crank
  • SCAT 5.7" floating pin I-beam rods
  • SRP +.030 forged pistons; -16 dome for 11.2:1 with 54cc heads. Zero deck w/FelPro gasket for .039 quench
  • Stock aluminum LT1 heads with mild porting
  • GM HOTCAM Kit (cam, springs and rockers)
  • Stock intake
  • 52mm TB
I'm (finally) starting the shortblock assembly this weekend and I'll start posting pictures and parts lists!
Old Oct 10, 2007 | 07:34 PM
5abivt's Avatar
5abivt
Cool keep us posted ! My .02 would be to open up the main and rod bearings a bit more than stock. The stock clearances are on the tight side which results in a lot of bearing failures when the LT1 is modified.
Old Oct 10, 2007 | 07:51 PM
billla's Avatar
billla
St. Jude Donor '14
Agreed on the rods - we opened up the rod clearances to .025 from the spec of .014 - .018. I'm not convinced that the main bearing clearance is a factor, so those are at the high limit.
Old Oct 11, 2007 | 08:22 AM
FD2BLK's Avatar
FD2BLK
My guess is you will be well above your goals in both HP and TQ. Probably cloaser to 450 at the FW in both TQ and HP. If you get a few Exrtra $$ I would get the heads CNC ported.
Old Oct 11, 2007 | 10:45 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
It's not so much the powered metal rods, it the stock bolts that are junk.
You might find the HotCam a little too mild for a 383. it's actually kinda mild for a 350.
Old Oct 11, 2007 | 11:06 AM
billla's Avatar
billla
St. Jude Donor '14
With the stock heads and HOTCAM, I think the numbers are right in there. 450HP would be within reach with better heads like AFRs.
Old Oct 11, 2007 | 11:08 AM
billla's Avatar
billla
St. Jude Donor '14
Not sure about the rod comment - I haven't heard of any PM rod failures, and GMPP sells them as the new "pink" rod. The factory clearances are definitely tight, though.
This wasn't a max-performance build as it's a daily driver - definitely agree that there were stronger cam choices available.
Old Oct 11, 2007 | 11:14 AM
Z06_BluByU's Avatar
Z06_BluByU
I think it will be tough getting 400 fwhp out of that combination unless you have a full after market exhaust and headers.. The hotcam is too small for a stroker.. mine idles like a stationwagon.. see sig for my mods and dyno results.. (granted this is on the dyno known as "the heartbreaker").
Old Oct 11, 2007 | 11:15 AM
Z06_BluByU's Avatar
Z06_BluByU
Also, I should note I used the stock rods but with ARP rod bolts and the stock clearances.. its been strong for the last 40k miles or so... it is my daily driver!
Old Oct 11, 2007 | 11:32 AM
billla's Avatar
billla
St. Jude Donor '14
CIA Tri-Y's + exhaust
Again, not a max performance build - I drive this thing every day.
Old Oct 11, 2007 | 12:12 PM
FD2BLK's Avatar
FD2BLK
Many LT1 HC 350's are above 400FWHP and not far off on TQ with ported stock heads, take a look at Nathens combo for a refernce, just one example. The HC is a mild Cam for a 383 but should be a great daily driver. Guess we will see but I would expect 360-370 RWHP/RWTQ out of that combo with a good tune. Just a note if I remember correctly those pistons with a 4.030 bore and 3.75 stroke are closer to 10.7:1 with the stock heads and stock gaskets.
Old Oct 11, 2007 | 12:57 PM
billla's Avatar
billla
St. Jude Donor '14
I will be going to the chassis dyno afterwards, so we will see
The engine is zero-decked and I'm using the FelPro .039 compressed gasket. The aluminum heads are 54cc and I took a mild cut on the head, so I should be right around 11:1
Old Oct 11, 2007 | 01:15 PM
BrianCunningham
With a stock bottom end, if you bump the rev limiter too much, you'll spin a rod bearing for sure. I've know too many people who have done it.
Old Oct 11, 2007 | 01:24 PM
billla's Avatar
billla
St. Jude Donor '14
ARP studs in the mains with an align hone, rotating ***'y balanced, and a rev limit of 5700. I have 3.73 gears, so it really puts this big beast in the sweet spot of the engine.
I'm using a Melling 10552 high pressure, 10% increase in volume pump with a 3/4" pickup with the stock pan and windage tray (1" longer ARP studs to clear the stroker).
Old Oct 11, 2007 | 02:17 PM
JAKE's Avatar
JAKE
I agree.
Jake
To LT1 383 Build
