Fuel Cutoff..
Old Oct 10, 2007 | 11:16 PM
derekguzz's Avatar
derekguzz
Default Fuel Cutoff..
ok i have been trying to practice my takeoffs for when i go to the trac. but when i rev it to like 2500rpm's and drop the clutch my car doesnt bogg down but almost. I can do burnouts if i rev it higher. but maybe i thought im not reving it high enough. i just wanna chirp my tires and take off. but its like cutting off. and another thing. going into my apartment parking lot theres a little hill i have to go up. i was in first gear and JUST let the clutch out trying to go up it and i tried to spin my tires and the fuel did the same thing. whats wrong? new injectors? i dunno. but on a flat strait away with the clutch out i can hit the gas and it doesnt do it. its fine. just certains times.
Old Oct 11, 2007 | 03:49 AM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Remember, we are here to help you.
Randy
BTW, IBTL
Old Oct 11, 2007 | 04:10 AM
derekguzz's Avatar
derekguzz
When I rev my car up to about 2000 rpm's I drop my clutch. My fuel shuts off and I have to right away put my clutch back in. I am doing this because I am practicing my launches for when I go to the track.
My car doesn't shut off, It's just sort of gasping for more fuel. I guess the next thing someone would say is ' give it more gas". But i do and it stutters more. Im asking if it coould be my injectors? Or my fuel pressure regulator? Im not sure. If I rev it higher and drop the clutch, I do a nice burnout. Should I not worry about it and bring my rpm's to a higher level, just not enough to do a burnout? Im not sure
Old Oct 11, 2007 | 05:45 AM
toptechx6's Avatar
toptechx6
Originally Posted by derekguzz
You guys are soo gay. Who cares about spelling? Yeah it makes things more clear and easier to read, but im not typing in a different language.I need advice about whats going on not advice on how to spell. Ok ill clear things up!
That last comment just confirms the perception your writing skills project to others.
Old Oct 11, 2007 | 08:27 AM
mseven's Avatar
mseven
COULD BE many things, tank is less than half full, clogged filter, etc.etc.
start trouble shooting, and off the personal attacks at members. IBTL
Old Oct 11, 2007 | 11:20 AM
Dale1990's Avatar
Dale1990
St. Jude Donor '15
I would hook up a fuel pressure gauge (available at most auto parts stores) and try your launching. You should be able to tape the gauge to the windshield well enough for a short drive.
Unless you've changed your pressure, you should see mid-high 30's psi at idle and low-mid 40's at WOT (someone correct me if I am wrong). If the pressure drops significantly when launching then you have a fuel problem - low level in the tank, plugged filter, bad pump, etc. If it stays in range, then I would look at ignition next.
And, we all make spelling and grammar mistakes but please try to proofread your posts. Trying to decipher your posts makes it more difficult to help you. Attacking respected members is not a good way to persuade people to help you, either.
Old Oct 11, 2007 | 11:29 AM
NEVRL8T's Avatar
NEVRL8T
This is exactly what I would do.
Old Oct 11, 2007 | 11:41 AM
Aardwolf's Avatar
Aardwolf
Old Oct 11, 2007 | 01:03 PM
derekguzz's Avatar
derekguzz
I wasnt attacking anyone. Im simply trying to ask a simple question. I get crap from everyone everytime I say something. It's annoying and it makes me not want to be on this forum anymore. For those of you who have helped me without trouble I thank you. For those of you who give me hell I thank you for the help you try and give me. But as far as my english, Im not concerned nor am I going to waste time thinking about it. Im going to give this forum a break for a while and cool off for a while. No one has to repost to this forum. I wont be checking it. Bye
Old Oct 11, 2007 | 02:52 PM
CFI-EFI's Avatar
CFI-EFI
RACE ON!!!
Old Oct 11, 2007 | 03:07 PM
toptechx6's Avatar
toptechx6
To Fuel Cutoff..
