AIR Pump Removal
Old Oct 11, 2007 | 08:42 AM
cfi's Avatar
cfi
Default AIR Pump Removal
Good Morning
I have seen posts that discuss the pump removal. I have searched the site and archives and have not found an answer to the following.
Does one need to make adapt etc. a new bracket for the alternator.
What about th eserpentine belt routing?
Thank you all in advance for an answer or link.
1989 red coupe
Old Oct 11, 2007 | 08:48 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If you eliminate the pump, you need an eliminator bracket with pulley. It will brace the top part of alt, lower alt bracket is still used. Factory belt length and routing, stay the same.
There are aftermarket eliminator brackets available or you can build one.
Here's a pic of my home built one.
Old Oct 11, 2007 | 11:32 AM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
Originally Posted by cfi
Good Morning
Don't know how your searching, but just did one for "air pump eliminator" and came up with 400 posts, all info there.
The search function to use is on the main menu bar beside "My Recent Topics", Click Advanced search, put in search topic, at the bottom, Click box "Archive", select forum (general or Tech) and you will find all..
Old Oct 11, 2007 | 02:00 PM
cfi's Avatar
cfi
Thank You Vinnie
Thank You Agent 86 nice motor
Old Oct 11, 2007 | 02:35 PM
CFI-EFI's Avatar
CFI-EFI
Oh Oh. I see future problems, here. I'll bet you think "cfi" stands for "certified flight instructor".
RACE ON!!!
Old Oct 11, 2007 | 03:54 PM
KeyWestJack's Avatar
KeyWestJack
Please next time you post pictures of you car and in particular its engine give fair warning, for those of us that need sun glasses. SWEET!!!!
Old Oct 11, 2007 | 05:35 PM
black85's Avatar
black85
I got mine from Breathless Performance. Very nice product. I may be modifying to make some room for other mods.......
Old Oct 12, 2007 | 09:31 AM
cfi's Avatar
cfi
Of course flight instructor. But my current airplane is slower than the vette.
Old Nov 17, 2007 | 11:12 AM
korvette4u's Avatar
korvette4u
nice new addition of a super ram, just beautiful!!!
"There are aftermarket eliminator brackets available or you can build one---->>>>>>>>>"
yupp there is !
Old Nov 17, 2007 | 11:43 AM
jhammons01's Avatar
jhammons01
When you pull it off give it to this guy
http://forums.corvetteforum.com/show....php?t=1865979
Old Nov 17, 2007 | 12:46 PM
TA's Avatar
TA
Here's mine from Breathless Performance. Not quite as pretty as Agent 86's, but you get the idea. Oh, I'm from Lansdale also.
Old Nov 17, 2007 | 02:16 PM
thirdtimevetteowner's Avatar
thirdtimevetteowner
Default Air Pump Delete Brackets
There is a guy (Dennis) who is building very nice delete brackets. Look up korvette4u, and you will find the link for his brackets. I just got one yesterday...excellent craftsmanship. They come in natural finish, or polished, both with a SS pulley and spacers. I have a photo of one in "my photos" secton, but can't figure out how to get it on here. At any rate, his site has photos and he will answer any questions you may have.
Rich K
Old Nov 17, 2007 | 02:56 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Rich K
I just got one also, it will be going on soon.
Old Nov 17, 2007 | 08:32 PM
Chapindad's Avatar
Chapindad
How much H.P. do you gain by removing it?
Old Nov 17, 2007 | 09:10 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
None, just cleans up the engine compartment, significantly. everything else is easier to work on.
Old Nov 17, 2007 | 09:11 PM
86GoldProject's Avatar
86GoldProject
not sure of the actual number, but it equates to very very little.
Old Nov 30, 2007 | 09:51 AM
atcdork's Avatar
atcdork
Cruising
I am going to remove my air pump and replace it with the eliminator too. I also want to remove the control valve and all the associated hoses. Basically, I'll remove everything up until the check valves at the exhaust manifolds and the one going to the cat.
Since I will be unplugging two ECM connectors (and leaving the connectors unplugged), will this set of a code and check engine light?
If so, what is the solution to that?
Thanks,
Ed
Old Nov 30, 2007 | 10:02 AM
jsup's Avatar
jsup
Rich K
I just purchased one of his too.
Old Nov 30, 2007 | 03:21 PM
AGENT 86's Avatar
AGENT 86
Thanks,
Ed
No codes will be set.
To AIR Pump Removal
