C4 Making Tapping sound
Old Oct 17, 2007 | 10:10 AM
C4 Struggle's Avatar
C4 Struggle
6th Gear
Originally Posted by Steve20
I hope the mechs didn't take it for a 'test drive' after completing the tune up? Bounce it off the rev limiter a few times in a row = tick?
If they did that I would have smoke out the exhaust, correct? I don't believe that is what they did. I'm going to have to check the plugs and verify they used the correct Mobil Motor oil.
Old Oct 17, 2007 | 12:13 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
No, you can screw up a lifter and not have any smoke coming out.
Try to pin down where the noise is coming from.
valve covers, fuel rail, spark plugs, exhaust, belts.
I had a tick once, it turned out the exhaust was loose.
Another time it was the dust cover on the clutch.
My lifter had a tick when I took the car out of storage, after I changed the oil it was fine.
They might have flushed some crud into the lifters.
But find out where the noise is coming from.
Can you post a VIDEO?
Old Oct 17, 2007 | 12:25 PM
WW7's Avatar
WW7
Brian is correct about crude or dirt making a lifter tap, sometimes a piece of dirt can clog a lifter and will make it tap until it comes loose. WW
Old Oct 27, 2007 | 10:37 AM
swisman2000's Avatar
swisman2000
1st Gear
Default noises ??????????
Originally Posted by C4 Struggle
Is there a special tool used while making sure the rocker arms are tightened. Are the valve covers easy to pop off and pop on? Why would the rocker arms suddenly come loose in the first place.
it would not be the first time a gm emplyee took a vet for one hell of a joy ride ....................over reving the motor , doing burn outs on your tires and gas, lot jockies can be the worst.
Old Oct 27, 2007 | 11:14 AM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
My vote is a poorly seated spark plug wire
I ve had it happen before
