C4 Making Tapping sound
Old Oct 16, 2007 | 08:10 AM
C4 Struggle's Avatar
C4 Struggle
6th Gear
Default C4 Making Tapping sound
I have a 1994 LT1 Corvette. I recently had the car in the shop for a tune-up, Brakes and all fluids changed. I also replace 2 sensors.The car currently has 86,000 miles on it. When I picked the car up from the shop I notice a new sound. It has a tapping sound coming from the compartment of the engine. I'm not sure what it is
Old Oct 16, 2007 | 08:52 AM
LouisvilleLT4's Avatar
LouisvilleLT4
Perhaps your odometer has started tapping now that it has spun past the number 86000. I doubt it's the new brake fluid or the two new sensors you don't have the names of though.
Old Oct 16, 2007 | 08:59 AM
evmlarry's Avatar
evmlarry
Have you tried to pinpoint the location of the noise? Could be any number of things. Try to find a specific area of where you hear it.
Knowing what sensors were replaced would definitely help too.
Old Oct 16, 2007 | 09:13 AM
Demonic85's Avatar
Demonic85
The knock sensor can make a tapping noise, but it shouldnt if your using the correct octane.
If its coming from inside the engine, it could be numerous things. On top means the valves are making noise, in front could be timing chain, or god forbid its coming from the bottom thats not good. Noises from the bottom could be a spun bearing
Sorry i'm not trying to freak you out, I highly doubt with your low miles that it would anything serious.
Old Oct 16, 2007 | 09:57 AM
Chatman's Avatar
Chatman
Have you lifted the hood and tried to locate the sound?
I recommend that you buy a mechanics' stethescope. It looks like the doctors' device with a tube leading to a diaphragm and metal rod. Pull off the diaphragm and metal rod and you have a plastic tube that you can move about the engine bay until you locate the sound more precisely. Once you have, ask your question again.
Your concern is that the mechanics screwed up something, right? Are you certain that you are hearing a new noise or just listening more closely because you just had repairs done?
Not matter what, you will want to know the source of the noise and the tool will help. I bought mine at Sears. Check to see if they have one before you make the trip.
Old Oct 16, 2007 | 11:06 AM
C4 Struggle
6th Gear
It sounds like it's coming from the top of the engine. The mechanic stated the lifters.
Old Oct 16, 2007 | 11:09 AM
Red Tornado's Avatar
Red Tornado
check your spark plugs and make sure they're all tightened sufficiently. its possible one or more wasn't tight enough when they were changed out during the tune-up.
a loose spark plug will definitely cause a tapping sound, very similar to lifters. if the sound didn't occur before taking the car in, i'll bet a loose plug is the cause.
Old Oct 16, 2007 | 12:01 PM
C4 Struggle
6th Gear
If it was a loose spark plug, would'nt the car miss/hesitate while running? The car is not missing or hesitating.
Old Oct 16, 2007 | 12:04 PM
Demonic85's Avatar
Demonic85
A loose spark plug wouldnt tap unless the piston was hitting it. It could be the lifters but more than likely its the rocker arms. You can take your valve covers off and see if you can wiggle them. They should be on there pretty tight. They will make an obnoxious tapping noise if they're not tightened down just right.
Old Oct 16, 2007 | 12:11 PM
C4 Struggle
6th Gear
Is there a special tool used while making sure the rocker arms are tightened. Are the valve covers easy to pop off and pop on? Why would the rocker arms suddenly come loose in the first place.
Old Oct 16, 2007 | 12:15 PM
rick lambert's Avatar
rick lambert
not only could it be a lose spark plug, but I'd want to make sure they hadn't cross threaded one...which is easy to do on our aluminum heads. You really don't have to get a stethascope, a short piece of old garden hose works well also.
Old Oct 16, 2007 | 12:26 PM
rick lambert
Old Oct 16, 2007 | 12:28 PM
Steve20's Avatar
Steve20
I hope the mechs didn't take it for a 'test drive' after completing the tune up? Bounce it off the rev limiter a few times in a row = tick?
Old Oct 16, 2007 | 12:30 PM
cv67's Avatar
cv67
St. Jude Donor '05
I was thinkin what Steve posted also, but-
A loose plug can make that sound, beleive it or not. It will still fire Ok too. Best bet is a stethescope to narrow it down.
Old Oct 16, 2007 | 12:38 PM
96 lt-4's Avatar
96 lt-4
probably a remote possibility but it happened to me recently.i bought mine with 89k miles on it.always had a slight tick.adjusted the valves several times and no changes.it never got any louder so i left it alone until at 103k it goud louder.then really loud like it was coming apart.
we thought it was a lifter about to come apart internally(i wish).
come to find out the thrust bearing on the crankshaft was shot and when it got really loose i was hearing the counterweights touching the block.not good.rebuild time.
if yours is'nt a six speed then all of that was useless babble.
Old Oct 16, 2007 | 01:01 PM
C4 Struggle
6th Gear
Is this common for LT1? I do have a 6 speed It just started happening after being in the Shop for a tune-up and brakes, fluids etc.
Old Oct 16, 2007 | 01:03 PM
rickneworleansla's Avatar
rickneworleansla
No, but it will make a tapping sound.
I had a loose plug a few months back. It made a tapping sound similar to a lifter. There was no noticeable miss. My mpg did go down quite a bit. I tightened the plug. The sound went away and mpg went back up.
To C4 Making Tapping sound
Old Oct 16, 2007 | 01:14 PM
Red Tornado
exactly. thank you.
Old Oct 16, 2007 | 06:58 PM
'Shifter's Avatar
'Shifter
St. Jude Donor '08-'09-'10-'11-'12-'13-'14-'15-'16-'17
NCM Member '09
My car did this at 120k, right after I changed oil when I got it....I ran Red-Line 10w30, as I do in all
my cars. It knocked like mad....I figured it was lifter, rocker or bad filter bypass valve....who would
have thunk I was running an oil too thin for teh motor?
Anyway, I ran some 20w50 Valvoline Racing and a quart of Lucas oil stabilizer...sound is now gone.
I stepped back to 10w40 synthetic without teh stabilizer, and teh sound is gone....
I'm not sure what it was, but the problem is gone...
Old Oct 16, 2007 | 08:35 PM
96 lt-4's Avatar
96 lt-4
i would'nt say it is common as i had'nt heard of it until this.i would check all the small stuff before i got worried.
