Blower motor relay
Old Oct 17, 2007 | 09:25 PM
FL87Z52's Avatar
FL87Z52
Default Blower motor relay
I'm having problems with the blower. I've been told to check this relay. Where is it?
Old Oct 17, 2007 | 09:32 PM
jfb's Avatar
jfb
Does your Corvette have a year? Why don't you tell us so we can better help you. If you have the electronic climate control where you select a digital temperature and blower speed, then you don't have a blower relay. Only the manual climate control has a relay and it is located just to the left (as the driver sees it) of the blower motor on the firewall.
Old Oct 17, 2007 | 09:36 PM
FL87Z52's Avatar
FL87Z52
It's a '87 with the climate control. Everything works with the air there is just no air coming out of the vents. I also have no power at the blower motor connections
Old Oct 17, 2007 | 09:40 PM
jfb's Avatar
jfb
Do you have the manual climate control (uses a lever to select temperature) or the electronic climate control?
Old Oct 17, 2007 | 09:46 PM
FL87Z52's Avatar
FL87Z52
sorry I meant to add it's electronic
Old Oct 17, 2007 | 09:52 PM
jfb's Avatar
jfb
Check your gages fuse and the ctsy/clk fuse. Then check the fuse located near the blower motor.
Old Oct 17, 2007 | 09:55 PM
FL87Z52's Avatar
FL87Z52
I check the fuse in the fuse panel and the fuse at the blower motor and they are both fine
Old Oct 17, 2007 | 10:25 PM
jfb's Avatar
jfb
Looking into the firewall (engine side) on the passenger side you see the blower motor and the a/c evaporator housing on the blowers right. On the top of the evaporator housing is the blower control module and two wiring harness plugs. The plug closest to the front of the car has a large red wire. Unplug that connector and measure the voltage on the large red wire pin. It should be the battery voltage and if it is zero, then the fusible link on that wire is blown and should be replaced. Behind the battery is a bolt with 8 red wires and the red wire from the blower control module is one of the wires on that bolt.
Old Oct 18, 2007 | 07:32 AM
FL87Z52's Avatar
FL87Z52
I tested for power at the connector I have power at both pins. I didn't measure the volts though. Could the blower control module be bad itself. I had on good bad on a 86 that I used to own, it won't shut off the the blower and would kill the battery.
Old Oct 18, 2007 | 08:38 AM
jfb's Avatar
jfb
Yes you could have a defective blower control module. The only way I know of checking it easily is to replace it. You did jump 12v to the blower motor to prove it is ok didn't you? The motors have brushes that eventually wear out and the motor no longer runs.
Old Oct 18, 2007 | 07:09 PM
SunCr's Avatar
SunCr
Make sure the blower works by jumpering it to the battery and then check for voltage at the blower motor. At "1", it should have 4 volts on the Black/Red or Purple wire (or whatever isn't black at the Blower) and at "10", 12 volts. Also make sure the connector is good - too much draw or a voltage drop due to loose terminals can melt the wires. Then check the input signal from the Dash Controls to the Module which is on the Brown wire - though it may look black with age (and while you're at it, check the Black wire which is spliced into the Blower Motor ground and terminates on the frame providing a ground for the Module and the Blower Motor). That Dash input should have 2.5volts at "1" and something around 6 volts at "10". If theres nothing from the Dash, the Dash Controls aren't working. If the Module has the input, but nothing out and Power and Ground are good, the Module is bad.
Old Oct 18, 2007 | 07:32 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
http://members.shaw.ca/dankai/AC%20Electronic.pdf
Old Oct 18, 2007 | 07:48 PM
The Green Hornet's Avatar
The Green Hornet
From: Everyone needs something to believe in, I believe I'll have another beer. Wisconsin
I was having trouble with the blower working on my 91 with electronic control, seemed to work when it wanted but not when i did, altho lately seldom at all. While reading thru some threads i came across one that sounded similar to mine. it had to do with the wearing out of brushes in the blower motor. i went outside,started the car, and set the fan speed to 10. Of course it didn't start blowing because of some problem, i opened the hood and rapped on the blower motor with a pair of lineman's pliers and it started working guess I'll be changing out the blower motor in the not to distant future.
Old Oct 18, 2007 | 08:52 PM
SunCr's Avatar
SunCr
I don't know - I hate hitting stuff and possibly breaking something when it's easier to just check for volts with a DVM. On the other hand, these old plastic connectors tend to break when you pull on the tab, so it probably doesn't matter.
Old Oct 20, 2007 | 11:50 AM
FL87Z52's Avatar
FL87Z52
Problem solved it was the blower control module. I tested for power I had power to it and not the blower, so I went to a junk yard and pulled 3 from some caddies with the electronic climate control. The first one didn't work but the second did and works great. I think the old one hasn't worked right for a while the air. So 16 dollars later and I have air again. Thanks for all the help.
To Blower motor relay
