Intake Gasket trouble
Old Oct 22, 2007 | 07:13 PM
Rockcreek's Avatar
Rockcreek
3rd Gear
Default Intake Gasket trouble
Have 96 LT4 383 stroker & everytime boost goes to 8lbs blows rear of intake seal out. Compression test is perfect so was thinking I might having hose or leak in intake I haven't found. Has anyone had simular problem? Thanks, Rockcreek
Old Oct 22, 2007 | 09:12 PM
tjwong's Avatar
tjwong
You need to vent the engine better to relieve the crankcase pressure. I would suggest adding two breathers or a catch can with a large breather.
Old Oct 23, 2007 | 05:07 PM
mn_vette's Avatar
mn_vette
Make sure that your PVC isn't blowing into the crank case. If the valve is stuck open it could be causing some problems.
To Intake Gasket trouble
