Pre-detonation
I have a 160 degree thermostat. I don't think it's the original motor either. Would 6 degrees BTC be correct for newer (86-89) engines too?
Any suggestions from the Corvette forum brain trust? I've already tried GM top engine cleaner. Can't find any vacuum leaks. I need more things I can try. I've tried Octane booster and I've tried disconnecting the wire (br/tan) that you unhook to set the timing (it ran worse).
Could it be:
a) Base timing incorrect
b) ECM prom needs reprogramming
c) Carbon build up
d) all of the above
e) none of the above
Please help!
6* is stock timing, I'm running 8* base timing.
Can you find out whether the engine is stock or not? Your computer won't need programming if it's stock!
May need a good tune up.
Engine Speed................... 700 RPM
Vehicle Speed.................. 0 MPH
Coolant Temperature............ 176 F
Manifold Air Temperature....... 104 F
Throttle Sensor Voltage........ 0.42 VDC
Oxygen Sensor Voltage.......... 668 mV
Oxygen Sensor Transitions...... 151 #
Idle Air Position.............. 32 #
Air Flow Rate.................. 5 GPS
Injector Pulse Width........... 1.6 mS
Spark Advance.................. 0.0 DEG
EGR Duty Cycle................. 0 %
Integrator..................... 125 #
Block Learn Multiplier......... 160 #
Spark Control Counts........... 0 #
Closed Loop Status............. On
Fuel Mixture Status............ Lean
Battery Status................. Norm
Torque Converter Clutch........ Off
Park/Neutral Switch............ On
3rd Gear Switch................ Off
4th Gear Switch................ On
Power Steering Switch.......... Off
Learn Control.................. On
A/C Request.................... No
TROUBLE CODE STATUS
No current trouble codes present
Thanks!
Should be section 6E3-B
TROUBLE CODE STATUS
Thanks!
They should read 16 ohms or thereabouts. Measure ohms across the contacts of the injector plug-ins.
Gregg
only detonation, and pre-ignition. and yes, they are quite different...
if its audiable, its detonation. pre-ignition is silent, but much more destructive.
verify your ign. timing setting with the proper procedure, and adjust if needed. the above mentioned lean condition is also a possible cause.
The timing is only retarded once the code is set after the knock test is preformed.
How exactly does one check injector voltage? Can you be more specific as I am car electric challenged. This has been suggested before but I was too busy (driving it) this summer to work on it and forgot.
Can anybody publish or link to the FSM section 6E3-B please for procedure for 'spark knock and detonation'.
My bad on the pre-detonation. I've always called it timing ping.
Thanks all
Can someone tell me how to get the electrical connectors off the fuel injectors so I can check the resistence? I've tried squeezing them together to no avail and I don't want to break anything.
Thanks!
To check the resistance of the injectors, set the DVOM to OHMS and select the lowest scale that will read up to 20 OHMS. You are checking the injector,not the wiring harness. Touch one lead of the DVOM to each connector on the injector (makes no difference which lead goes to which connector) and note the reading, should be close to 16 OHMS I think, your car could be different. Similar to a compression test you are looking for consistency between injectors, be suspicious of any that are different from the norm.
You can check power to the injectors by setting your DVOM to DC volts, connect the black lead to a good engine ground, turn the ignition key to the "ON" position, there should be battery voltage at one of the two wires to each injector.
The ECM "pulses" the other wire to ground to fire the injector, the easiest way to check that side is with a "noid" light, a test device available at most parts stores, it plugs into the electrical connector you removed for the resistance check, if it flashes while cranking the engine over the ECM has the ability to fire that injector, hope that helps.
All injectors are getting power (12v) and read 16 ohms. I guess my next step is to check the EGR valve. Could someone please explain this process for me?
Is there any other way to find a vacuum leak desides spraying WD40 all over the visible vacuum line connections (already done)?
