Chasing the threads
Old Dec 15, 2007 | 09:57 PM
  #41
Carpenter's Avatar
Carpenter
Oh....I should add......
Re-reading my first post I admit to being somewhat offensive. I intended to minimize the need for a chase set only from my personal perspective. Sorry it was so brash sounding.
The good news is that my 383 has now run 15,000 miles (scarry fast too) without a glitch. I have yet to take it down the track but once I get DR's, I am excited to run. My new boss has a 426 that runs 9.80's (always boasting) and thinks vettes are 'wimmin's work'.....so I'm REALLY looking forward to impressing him with a low 11? Can I even dream of a high 10??? (I drive my vette to work.....he trailors his ~store built~ $100,000 dodge to the track)
Old Dec 15, 2007 | 10:30 PM
  #42
kalister1's Avatar
kalister1
You brought up a good point. Do NOT apologizes for making people THINK and discuss proper engine building techniques. Your idea / concept of making your own chase is good thought, we all need to think on our own.
Old Dec 15, 2007 | 10:48 PM
  #43
kalister1's Avatar
kalister1
Wow, you put a lot of miles on that car in 2 months!
Old Dec 15, 2007 | 11:42 PM
  #44
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
that's nothing, stop by PRC some time...
Old Dec 16, 2007 | 01:23 AM
  #45
Carpenter's Avatar
Carpenter
Two months??? Try almost two years now.
Old Dec 16, 2007 | 08:15 AM
  #46
Happydad's Avatar
Happydad
I'm a Tool and Die maker for most of my life...Taps can come in diff thread grades(classes)...Most off the shelf stuff is standard but the quality might be lacking..Brittle cheap China crap...Could snap off in the hole just running it in...If a thread is damaged then ya got no choice..Go slow and start straight also back off to clear chips..Anyway a thread chaser is the only way to go just to clean out threads...JMHO
Old Dec 16, 2007 | 10:39 AM
  #47
kalister1's Avatar
kalister1
I was going by the date of your original post. Must be a different motor?
Old Dec 16, 2007 | 10:41 AM
  #48
jsup's Avatar
jsup
Threads also have "fits" too. I don't know the technical term.
For example, on one fit thread you can spin a nut all the way to the bottom of a bolt with one hit.
On the other hand, on a different fit thread, the nut will go down tighter, and you'll have to hold a nut with something to drive it down, even though they are all the same spec, like 3/8 NC.
Old Dec 16, 2007 | 10:44 AM
  #49
kalister1's Avatar
kalister1
The way i understand it, you turn the tap in to create a chip then back it off to break the chip off.
The last time i looked a Machinist Handbook there were 3 classes of threads. I used to sit in Incoming Inspection and MIC the screws we did not have Go-NO-Go gages for. Those 3 little wires are a bear. I finally learned to use a Rubber Band to hold them.
