L98 performance suggestions
Old Nov 6, 2007 | 09:47 AM
Draven's Avatar
Draven
St. Jude Donor '14
Originally Posted by jsup
You always crack me up. So basically, if you just trash everything but the block, that will really improve an L98.
Actually, no, he wants to cut / crank the block so that's out the window too.
The first step in his equation is buying the longblock from the builder. : )
Old Nov 6, 2007 | 12:40 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
With new heads, cam, crank, ect...
So I guess the "improvment" to the L98 is if you keep the valve covers and PCV.
Old Nov 6, 2007 | 02:03 PM
RandyJ75's Avatar
RandyJ75
St. Jude Donor '06-'07
Here is what I would do. Pull the engine, and find a shop that can rebuilt the bottom end. W/ 172,000 miles, I'am sure it needs it. You can have it bored .30 over or go w/ a 383 kit. Look around on the for sale section here and at thirdgen.org for a set of 113 alum heads. Have the heads rebuilt w/ LT4 hot cam springs, and pick a cam (lots of good advice above). Then find a modifed LT1 intake, and a set of headers, and you should be good to go.
Randy
Old Nov 6, 2007 | 02:23 PM
GeosFun's Avatar
GeosFun
I read your initial question to say you wanted to stay with the TPI because you did not want to mess up the comuter (read that "chip").
In my opinion, the TPI is THE limiting factor in an L98. A Super Ram will not affect your computer at all. Nor will any larger aftermarket intake and runners such as TPIS, etc. But a big cam change would. I think you'd be very safe with an Accel 211, TPIS ZZ9 or similar cam. Although I have not run them, I believe they are excellent mild cams (I have Accel 219 and it will run with a stock chip, although I have a custom chip).Once you are inside the engine, you might as well bite the bullet and do a cam too.
No one has ever complained in this forum about too much power. My experience has been the engine usually does not run a strongly as hoped for, so i suggest plan a bit more than you think you need, and just find some competent local help. It is not that expensive and you will be driving a long time. This forum is a great place for that kind of help too.
Old Nov 6, 2007 | 09:15 PM
jsup's Avatar
jsup
Having gone through months of research, second guessing, rethinking, and re-assesing, I have come to a conclusion:
People are not happy with their mods because they do not take the time to research the best COMBINATION of what they are doing. I believe people tend to put too much cam, or too much head, or too much valve, or too much injector, or something to that effect into their build.
Then when the car has dead spots throughout the range, bogs on acceleration, ect....
This was typical when I was a kid and people would throw 850 CFM carbs and larger on 350s and wondered why it ran like crap.
Big enough is usually enough. Too big is bad.
Old Nov 27, 2007 | 04:56 PM
Toypar's Avatar
Toypar
LMAO Yead try forced induction with a 58cc combustion chamber and there will be nothing left. It might throw the piston straght out the side of the block
Old Nov 27, 2007 | 05:06 PM
Toypar's Avatar
Toypar
Go to MSD Ignitions website and there is a Injector calulator that can tell you exactly what CFM you need to support your engine and what Injectors as well.
