L98 performance suggestions
so I am unconcerned about maintaining originality.I want to keep the TPI stock so as not to mess up my electronics or computer. I will replace the timing chain of course with a double roller. While it is torn down, are there any suggestions out there for the following:
- Cam (roller, non roller, specs?)
- Rockers (1.5, 1.6, roller?)
- Heads (valve size, CCs, compression?)
My goals is 50 to 75 horsepower over stock with good drivability. Is this within reason and how should I go about it. I am open to all suggestions.
You should think about porting the plenum, intake, get some larger runners and put some alum heads on there--the computer should handle that.
Roller cams are nice but not cheap.
If you search you will find lots of threads with suggestions on heads and cams.
I had a problem getting the right timing chain, which set me back a week.
I had to travel for work, last week, and this week.
When I get back next monday, I will pick up the parts from the powder coater, and assembly will begin.
I'd start the assembly now, but I want to check the intake base to the 1204 gaskets before I mount the heads, in case I have to take a little off the heads. I read that the Super Ram is 1205 gaskets, but I don't konw if that's standard or worked.
Guess I can just ask the question....
Exhaust is pretty good on the Vettes, heads are so-so. If your an '85 then you have the iron heads I think? Correct me if I'm wrong guys.
Vortec heads with the baseplate is a good deal and a definate step in the right direction.
Camshaft is key. I like the Lingenfelter 219. You can buy it new on ebay for about $250 and It's a very streetable cam that makes great power in the long tube TPI.
then there's tuning and of course I would expect your already performing the "free mods"
My advice, Do a little at a time. Drive it until you get bored and think about what you want to do next.....
Exhaust choices are all based on sound preference, you have to hear them to decide. Headers are on fit & quality, like TPiS or Hooker.
Next step, start shopping these parts and see if you have the budget. This is not really a first timer home project. Do it all at once get a pro to install it if you have the money.
You can do and achieve your 50-75 gain without touching the cam if you want. I am running the stock cam and pistons currently.
heads + cam + intake + LT headers/exhaust......minimum.
the above + added cubes, preferably.
add a supercharger, if desired.
if i had it to do over again, i'd do ALL of the above. and i've got no goals, i don't go to the strip.
