Gear Problems.. HELP
Old Nov 7, 2007 | 08:14 AM
anesthes's Avatar
anesthes
You should drop central coaster a line. He could probably give you some good advance on the flywheel.
I'm not entirely sure the FAQ is accurate and can be trusted about the ZF stuff.
-- Joe
Old Nov 7, 2007 | 11:41 AM
derekguzz's Avatar
derekguzz
should I take my car back to get the clutch/flywheel looked at or should I just get a new flywheel?
Old Nov 7, 2007 | 12:04 PM
cv67's Avatar
cv67
St. Jude Donor '05
Just get it balanced, you should be fine.
Welcome to the club as far as incompetent mechanics. Look in the regional sections here on the forum, I bet youll get plenty of choices from guys that are hooked up with good shops if you dont do your own wrenching. Weve all been there, dont give up.
Old Nov 7, 2007 | 01:47 PM
derekguzz's Avatar
derekguzz
Thanks guys. It sucks. But then again, its a corvette so it makes me feel better, specially when I lay some rubber down
Old Nov 7, 2007 | 01:55 PM
Vic'89's Avatar
Vic'89
Originally Posted by derekguzz
this new guy wanted 200. Now i know why.
Are you stating that this guys would drop your rear, install new gears, and re-install the rear for $200 !
That is insane.
I just had gears installed , and it cost me $400. I pulled the center section and took it to the shop.
Once they installed the gears I supplied, I re-installed the rear back in my Vette.
Vic
Old Nov 7, 2007 | 03:37 PM
STL94LT1's Avatar
STL94LT1
That is insane.
Got mine installed for $350. But, after the install the shop said they wouldn't do another C4 for that price.
Old Nov 7, 2007 | 08:47 PM
derekguzz's Avatar
derekguzz
yeah I drive it in and drive it out for 200, another shop said if i brought him my dif he would put in the gears for 150.00 but thats a forum guy (neat) ( name is josh) hes a great guy. its hard to find a reuitable guy..then my guy who installed my clutch/flywheel said 300-600..
