Electical Problems
Old Nov 10, 2007 | 06:53 PM
SlowRacer's Avatar
SlowRacer
4th Gear
Default Electical Problems
My Display on my 85' cuts out when i hit bumps. I need some advice on what it might be, and what ways i can fix it. Thanks
Old Nov 11, 2007 | 12:26 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Default digi dash
Lights or everything? I swapped mine out for a rebuild a while ago. My dash gauges still worked but the lighting system had died. I think I paid around 325 dollars exchange. I have realy enjoyed my new digi dash since replacement.
Old Nov 11, 2007 | 08:28 AM
badabing9's Avatar
badabing9
i would remive it and check, clean, and reinstall the unit and see what happens before shopping for a replacement.
Old Nov 11, 2007 | 10:36 AM
Sam Lam's Avatar
Sam Lam
There is a firewall connection directly behind the battery that goes to the instrument cluster. This connection has about 20 wires in it and supplies voltage to the instument cluster and its gauges. The connector is in an area where water can drain onto it and corrosion can be created. Remove the battery, open the connection, clean all contact areas with a pencil eraser, apply some OxiGuard to the connections and reconnect. Do this before you start buying or repairing. This will cost you very little, except for some time. It may solve your problem.....and it may not solve it. I'll bet a cold Bud Lite that you may be happy after you do the process
Old Nov 11, 2007 | 11:37 AM
jfb's Avatar
jfb
If only the backlights go out when you hit a bump, then you have an unsoldered pin on the front circuit board. The cluster has two circuit boards that plug into each other from a single row of pins on the front board into a socket on the rear board. The end pin closest to the center of the circuit board carries the lamp current and an age relaxed spring on the socket causes connection resistance. The lamp current flowing through this resistance gets so hot it unsolders the pin. Resoldering the pin will not cure this problem. I soldered a short insulated piece of hookup wire from the pin to the socket while the boards were plugged together and I haven't had any problems since (about 7 years ago).
Old Nov 11, 2007 | 10:20 PM
SlowRacer's Avatar
SlowRacer
4th Gear
Thank you very much for your reply. Oh yeah, your on about that cold bud light.
Old Nov 12, 2007 | 06:18 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default dash
Tap the area around the headlight switch. If the lights go off, or flicker, time to change the headlight switch or repair it's ground.
To Electical Problems
