VATS or electrical problem?
Old Nov 11, 2007 | 04:25 AM
Phalanx_vette's Avatar
Phalanx_vette
Default VATS or electrical problem?
I tried to start it up the other day and when I turned the key everything went out. All lights and power dropped. I opened the hood and disconnected the battery then reconnected it, when I shut the hood all the power came back, lights came on and all. So I tried again, but when I tried to turn it over same thing happened. I checked the fuses and none were blown, unless i missed some somewhere, but could it be the VATS? Or do I have a serious electrical problem? I don't know what's supposed to happen when the VATS isn't activated by the key. Are you supposed to lose all power?
Old Nov 11, 2007 | 07:54 AM
Nzzz's Avatar
Nzzz
VATS stops the car from starting. Heres a site that is useful.
www.vatssucks.com
I think your problem is electrical. No help there with that.
Old Nov 11, 2007 | 08:09 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Sounds like a poor connection at battery or power distribution block.
Old Nov 11, 2007 | 08:16 AM
yoitsmatt's Avatar
yoitsmatt
When vats has a problem the starter enable signal is shut down, the security light will be on and the car will not crank over like you had a bad starter but its because the starter isnt getting any voltage to the solenoid, if all the lights went out, (no headlights, interior lights, radio) then it isnt vats, start at the battery and work your way in....
Old Nov 11, 2007 | 08:23 AM
badabing9's Avatar
badabing9
Old Nov 11, 2007 | 08:30 AM
Phalanx_vette
Thanks guys. I'll give it a look. I'll try cleaning the posts and see if that does anything.
Old Nov 11, 2007 | 10:59 AM
Nzzz's Avatar
Nzzz
When you put them back on, make sure they are tight and not loose. That has happened to me before.
Old Nov 11, 2007 | 11:27 AM
jfb's Avatar
jfb
Poor battery cable connections, remove cables (neg first), clean the cable lugs, bolts, battery teminals and replace the cables (neg last).
To VATS or electrical problem?
