jack points
Old Nov 16, 2007 | 09:33 PM
signman920's Avatar
signman920
3rd Gear
Default jack points
1994 LT1, want to put wheel dollies under the wheels, were is the best place to jack the car up at? and with what type of jack?
Old Nov 16, 2007 | 10:47 PM
vinnies87's Avatar
vinnies87
St. Jude '03-'04-'05-'06-'07
1. Check Tech Tips
2. Use search function
3. Read owners manual
4. Look under the car for jack points marked with arrows
5. Floor jack
Old Nov 17, 2007 | 12:55 AM
86PACER's Avatar
86PACER
http://www.c4guru.com/articles/TowingJacking.pdf
Old Nov 17, 2007 | 07:52 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
If you place your floor jack on the frame directly below the mirror, you can jack up the whole side at one time.
Old Nov 17, 2007 | 11:54 AM
jhammons01's Avatar
jhammons01
Thank you 86. A quick one sentence answer is nice and all that is usually needed.
Old Nov 17, 2007 | 12:42 PM
STL94LT1's Avatar
STL94LT1
Old Nov 17, 2007 | 11:42 PM
Vett-eight-nine's Avatar
Vett-eight-nine
Then again the picture of the white Vette is worth a thousand words.
Nice wheels STL!
Old Nov 17, 2007 | 11:44 PM
jhammons01's Avatar
jhammons01
Nice wheels STL!
I grow weary of the "search" reply
Here and many other forums I frequent
Old Nov 18, 2007 | 12:17 AM
fnsblum's Avatar
fnsblum
Great looking wheels Michael! Have they been refurbed? Later! Frank
Old Nov 18, 2007 | 02:15 AM
rodj's Avatar
rodj
Doesn't work with Z51, can't get jack under;
I achieve same result using rear jack point
Old Nov 18, 2007 | 12:37 PM
STL94LT1's Avatar
STL94LT1
No, those are the stockers. It has 26k miles, and has been garaged since new.
Thanks.
-Mike
To jack points
