Be Cool radiator install
Old Nov 18, 2007 | 01:34 PM
Lars87's Avatar
Lars87
Default Be Cool radiator install
I am installing a be cool radiator in my 96, manual...
So far I have cut the rubber mounts, and trimmed the plastic in the lower mounts a bit, but they need more..
I looks like i need some kind of spacer to be able to screw the fan housing back togehter?
Have you made your own spacer?
Pictures are VERY welcome!
Old Nov 18, 2007 | 04:04 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Here ya go
Old Nov 18, 2007 | 06:06 PM
Lars87's Avatar
Lars87
thanks. I still dont understand how these mount..?
Vertical on each side, since there are 2?
Or horizontal on top?
Old Nov 18, 2007 | 07:19 PM
fc_soldier's Avatar
fc_soldier
Very nice...Got any pics of it in the car? Does it show at all when assembled?
Old Nov 19, 2007 | 10:24 AM
BrianCunningham
top and bottom
Sorry no installed pics, and I'm on a contract out in Denver.
take a look at the fan support along the top, you can see the stock bolts.
Old Nov 19, 2007 | 02:15 PM
Lars87's Avatar
Lars87
can you remeber the appx. dimenions on this spacer.
That way I can create mw own, since be cool dosent ship to Denmark...
Other than that the price eon the piece is set high.
Old Nov 20, 2007 | 02:12 AM
Movnviolation's Avatar
Movnviolation
I put a Be Cool in my 89. Went in like stock with no alterations. Looks factory.
I saw no real advantage over the stock radiator as far as sitting in traffic other than takes a little longer to heat up. I put a manual switch so I can turn on both fans. Also replaced the silly little aux. fan with a 14" tornado push/pull. That worked.
Post the results when you get set up!
Old Nov 20, 2007 | 08:49 AM
Lars87's Avatar
Lars87
what did you hope for sitting in traffic?
I hope that I see color temps on the track (road track)...
Old Nov 20, 2007 | 10:49 AM
ubnpast's Avatar
ubnpast
that looks really good
Old Nov 20, 2007 | 02:13 PM
all4c4lt4's Avatar
all4c4lt4
Have you considered installing an electric water pump for cooler temps, and since you already have the rad out?
Old Nov 20, 2007 | 03:53 PM
Lars87's Avatar
Lars87
No..When stock rad went leaking, so i got a used Be cool. I hope the BE Cool alone, will result in lower coolant temps on track.
Old Nov 20, 2007 | 04:27 PM
larryfs's Avatar
larryfs
what track temps did you see on a 96 ?
Old Nov 20, 2007 | 04:31 PM
Lars87's Avatar
Lars87
small tracks 212-230
bigger tracks 203-212
Driven HARD!
Old Nov 20, 2007 | 04:39 PM
fc_soldier's Avatar
fc_soldier
Old Nov 20, 2007 | 04:47 PM
larryfs's Avatar
larryfs
and is that with a 180 or 160 t-stat ??
Driven HARD!
Old Nov 20, 2007 | 05:07 PM
FD2BLK's Avatar
FD2BLK
I was able to bolt mine in but others have used a 1/2" spacer on the bottom if I remember correctly.
Old Nov 21, 2007 | 03:21 AM
Lars87's Avatar
Lars87
stock
To Be Cool radiator install
Old Nov 21, 2007 | 08:33 AM
larryfs's Avatar
larryfs
1 problem I do NOT have with my LT4 is cooling.
I have 9000 track miles, and my car runs cool with the STOCK radiator, and 160 thermostat.
I don't see why you are going through all that trouble, unless your stock rad blew out or something. Especially without simply doing a Tstat first.
Even if it gets up to 210-220, so what.
Old Nov 21, 2007 | 09:26 AM
Lars87's Avatar
Lars87
my stock rad DID blow...
I am not worried with my track temps at all, but hope to see it cooler after the be cool rad.
Old Nov 21, 2007 | 10:20 AM
BrianCunningham
I ditched my stocker when I cracked BOTH plastic side tanks at a road course
