4.10 Gears for D44
Old Dec 4, 2007 | 02:30 AM
Dr. Evil's Avatar
Dr. Evil
CI 1-2-3-4-5-6-7-8 Veteran
CI-IV AutoX Champ
CI-IV Burnout Champ
St. Jude Donor '07-'10
I've got the hotcam, headers and 4.09s. I still get 27mpg hwy. 23mpg mixed driving.
I only went with the dana 4.09s cause I got em (new) from a forum member that decided to go a different route so he sold me these very reasonable
That being said, they do make a bit more noise even though the pattern was fine. Its the nature of the 4.09s vs the 4.10s. The 4.10s are the better gear set but I cant complain for what I have in em.
Old Dec 4, 2007 | 10:59 AM
derekguzz's Avatar
derekguzz
I thought my fidanza flywheel was horrible. My flywheel is silent compared to my gears, but im taking it in tomorow. any chance they will come out quiet?
Old Dec 4, 2007 | 11:24 AM
lt1tyrell's Avatar
lt1tyrell
I found some gears on the ebay for like 165 bucks from a place called rons machining. He specializes in differentials. Anybody heard of or had good luck with this place?
Old Dec 4, 2007 | 01:28 PM
96lt4c4's Avatar
96lt4c4
Originally Posted by STL94LT1
I've been running Dana OEM (Viper) 4.10's for 5 years without a problem.
Where do you get the OEM Viper gears? Dealer?
Old Dec 4, 2007 | 04:32 PM
STL94LT1's Avatar
STL94LT1
I bought my Dana OEM 4.10's from a forum member that worked in the parts department of a GM dealership, they were in a GM labeled box. Unfortunately for others, he no longer sells the gears.
You should be able to pick up a set of the Viper gears at a Dodge dealership or somewhere online.
Old Dec 4, 2007 | 04:36 PM
STL94LT1's Avatar
STL94LT1
I doubt they will, sounds like a bad install
Old Dec 4, 2007 | 06:18 PM
derekguzz's Avatar
derekguzz
should he be liable for the damaged gears? are they damaged?
Old Dec 4, 2007 | 06:22 PM
Zix's Avatar
Zix
Did you break them in properly? If so then I would have him fix them to your satisfaction.
