Last minute advise...
Old Nov 21, 2001 | 11:58 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Last minute advise...
Hey guys,
This is the big weekend. I will be tearing my motor down for the installation of 190 AFR heads, 1.6 RR, 219 Cam, Accell Base, and topped off with a SuperRam. I have never done this on my ca before and was just looking for some words of wisdom. One thing that comes to mind is: Do I have to do anything with the A/C unit. I would hate to loose the gases in there. Let me know anything I should look out for or do while I am in there. I plan on learning as I go. Should be an experience. Thanks.
Old Nov 21, 2001 | 12:17 PM
Nathan Plemons's Avatar
Nathan Plemons
Default Re: Last minute advise... (ski_dwn_it)
If you are going to do the cam you will most likely have to purge the A/C system, I had to.
scorp508's Avatar
scorp508
I'm not positive if the condensor can stay in there to swap the cam. I know the radiator has to come out. Your best bet might be to go to somebody today who does AC recharging and ask them to hold your charge for you. Most places will do this for a small amount of $$ for being on the machine.
Just make sure you have a couple sets of gaskets for the superram, I am told they are easy to tear.
Old Nov 21, 2001 | 12:26 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (scorp508)
That is what I was afraid of. My brother owns a car dealership and they have a machine out there. I will give them a call and see if they can keep it for me. Thanks..anything else?
Old Nov 21, 2001 | 12:30 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (ski_dwn_it)
One other quick thing..the A/C unit is RW134 and not 12 right?
Old Nov 21, 2001 | 12:57 PM
Marcho Polo's Avatar
Marcho Polo
2023 C8 of the Year Winner - Unmodified
2020 Corvette of the Year Finalist (stock)
2019 C7 of Year Winner (stock)
Former Moderator
Cruise-In I-II-III Veteran
unless it's been converted, it should be R12. They didn't start going with 134a from the factory until '93 or '94 I think.
Old Nov 21, 2001 | 12:58 PM
art91's Avatar
art91
I've heard the Superram is a bear to install, and there are tips to make it easier, such as notching the lower plenum bolts so they can be turned with a screwdriver from above. I think Beachbum's site has some, and I did a Google search last week, and found other install tips.
Good luck, and keep us posted! Happy T-Day!
JonM's Avatar
JonM
By law its supposed to have a label on it, if it was upgraded to 134. However, the guy that is going to evacuate it for you has a meter to tell what it is 134 or 12.
Old Nov 21, 2001 | 01:00 PM
scorp508's Avatar
scorp508
An '89 is definitely R12 from the factory. That crap is expensive, like $50/lb now. I have to get mine recharged. And NO I'm not converting. :)
*edit*
Make sure you have plenty of engine assembly greases/fluids ready before you start. Take lots of pictures so that you know where the vacuum lines go when you reinstall. Label EVERYTHING. If in doubt, LABEL IT TWICE.
[Modified by scorp508, 12:01 PM 11/21/2001]
Old Nov 21, 2001 | 01:33 PM
Vic'89's Avatar
Vic'89
I hope you will give us some updates as the project unfolds.
Vic
Old Nov 21, 2001 | 02:51 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: Last minute advise... (Vic'89)
That really stinks if it is R12....man I wish it were the 134. He said that he could get me a conversion kit, but did not know how much it would run. Perhaps someone here could give me an idea. I will check to see if I can do the mods without disconnection it. Has anyone been able to remove the necessary items with loosing the gases? I am at work and was planning on starting tonight...The only thing I can see being in the way of everything is the radiator. All my smog stuff has already been deleted. Keep em coming. I will keep you all posted as often as important items arise. Man am I pumped up about this!! The only bad thing is I have to wait all winter to drive it :cry Later guys..
Old Nov 21, 2001 | 02:54 PM
scorp508's Avatar
scorp508
I wouldn't use one of those $35 conversion kits. A "real" conversion requires a R134a condensor, compressor, o-rings, oil.
Old Nov 21, 2001 | 03:28 PM
Marcho Polo
Former Moderator
yup, when I did my '85, I got the $35 kit, but I also bought a new compressor, accumulator, o-rings, orifice valve..... was a couple hundred bucks easy when I was done, and that's with me doing all the work. Worked great though.
Old Nov 21, 2001 | 03:41 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (Marcho Polo)
Well, If I need to change all that, then chances are I will not have an A/C unit this summer :eek: I never use the thing anyways. Just on occasions. Its usually crappy weather here in PA. I guess I will have to cross that bridge when I get to it. Thanks guys.
Old Nov 21, 2001 | 05:04 PM
ZylaRace's Avatar
ZylaRace
Why convert it? If it works, store it then recharge it. It is not a big deal, you just need to do it. R12 is a more efficient chiller, it will cost you less $ in gasoline.
I'm not sure if the condensor is inthe way or not. I have often wondered the same thing. One thingis for sure, you don't want to be bending any of that AC hardline stuff. You could play it safe, and save yourself a lot of hassel if you remove it as well.
Old Nov 22, 2001 | 12:53 AM
JonM's Avatar
JonM
If you wanted to convert ...
http://www.corvettemagazine.com/2000/July/ac/airpg1.asp
Old Nov 22, 2001 | 10:54 AM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: (JonM)
Thanks Jon,
I think I am going to try to work around the A/C unit. Its going to be a PITA but I think I might be able to pull it off. I can't believe that no one else has had this problem. Please chime in if you have been through this. Thanks
To Last minute advise...
