head confusion
Old Nov 22, 2001 | 12:57 PM
lowace's Avatar
lowace
8th Gear
Default head confusion
For my 86 stock block 350 with auto do I go with, AFR 190 74 or 68 Trickflow 64 or 72 Trickflow G2 67 Edelbrock 64 or 70 Also what about the AFR 180 Steet Head ?
Old Nov 22, 2001 | 03:30 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Default Re: head confusion (lowace)
It realy depends on the rest of the buildup. If cam and intake will support >190cfm, the AFR 190 sound like a good choice.
Old Nov 22, 2001 | 03:57 PM
DON M's Avatar
DON M
The AFR 190 heads are a proven choice, until cubes or a very radical cam require alot more flow. For L98 that's what I voted for.
Old Nov 22, 2001 | 10:26 PM
ski_dwn_it's Avatar
0ski_dwn_it
Former Vendor
Default Re: head confusion (DON M)
I just got the 190 AFR's. I got the 74cc and had them milled to the stock 58 cc. This was AFR's suggestion, it helps unshroud the valves = more air flow. The total setup with upgraded springs and valves was around 1800. Be sure to check cam lift to afr specs. The stock 190's are only good till .550. Anything larger requires the before mentioned upgrade. And don't forget about all the sensor holes, its only another 25 or so bucks. It will save many headaches down the road. You can follow my progress of my project on the post: The Project.... Good luck and if I can help in any way get in touch. :cheers:
Old Nov 23, 2001 | 01:46 PM
jeffie86/96's Avatar
jeffie86/96
Default Re: head confusion (ski_dwn_it)
I just purchased Edelbrock heads for my 86 and the quality is excellent, I haven't run it yet but expect good things. :chevy
To head confusion
