MAF for power!
Old Dec 4, 2007 | 01:07 AM
all show and more go's Avatar
Default MAF for power!
i've been reading the jegs catolog (wishlist) and read that u can increase 10-15 hp, is that true, im in neeed of one anyway
Old Dec 4, 2007 | 01:35 AM
80sRule's Avatar
80sRule
It's not true.
You car needs a nice used MAF. I bought mine from Jason at Vette2Vette for $70 shipped.
Old Dec 4, 2007 | 08:32 AM
LTxDave's Avatar
LTxDave
Its probably true, but its probably not 15 HP more at the peak of the HP curve.
Old Dec 4, 2007 | 09:14 AM
rick lambert's Avatar
rick lambert
I think alot of guys have shown there was no performance gain on after market MAFs. That said, if you're talking about the larger MAF housing, I think a couple guys have tried it and believe it did help HP, if memory serves it was about 9 HP. Hopefully they'll chime in.
Old Dec 4, 2007 | 09:26 AM
FD2BLK's Avatar
FD2BLK
I tried the Larger MAF housing and it did't do squat. I believe Jesse also tried it with a 10 second car and it did not improve his ET a bit. In order for a larger MAF housing to help it would need to be the limmiting factor for intake airflow and in looking at Ski's results that is far from reality. He makes a hell of a lot more power then most of the cars on this board and the MAF still was not the limmiting factor. Just my 2cents
Old Dec 4, 2007 | 10:25 AM
tjwong's Avatar
tjwong
Don't waste your money, in fact if you install a larger MAF you may even loose power because the new unit will not have a calibration that coincides with the PCM MAF table that is programmed in the PCM or your ECM.
Old Dec 4, 2007 | 10:28 AM
rickneworleansla's Avatar
rickneworleansla
Which type are you referrring to? The Granatelli has a different sensor that fools the PCM into leaning out at WOT. I would get a custom tune for this instead. A custom tune is much cheaper and has many additional benefits. There are many arguments for and against descreening or porting the MAF housing. You'll have to read both sides and decide for yourself. If nothing else maybe a plastic housing will help by not retaining heat. They go for about $40. Mine idled and ran fine after the install but it may still require some tuning.
From last week.
http://forums.corvetteforum.com/show....php?t=1874880
Old Dec 4, 2007 | 11:14 AM
Jonnymac's Avatar
Jonnymac
St. Jude Donor '08
I have seen more then one dyno showing the plastic housing adding hp. I have one myself and do not regret buying it.
Old Dec 4, 2007 | 11:36 AM
rick lambert
The plastic one is what I was referring to, isn't it a little larger too? Thought the test showed 9HP, hardly something you'd feel. Nevertheless...9HP is a sizeable gain for $40.
Yeah, that's the site....or rather the website is posted there, seems like an unbiased test, read the other parts they tested and decide for yourself.
Old Dec 4, 2007 | 11:37 AM
Demonic85's Avatar
Demonic85
Just bought a new one for $190, went the used route last time and it lasted 2 months
Old Dec 4, 2007 | 11:50 AM
DVNCI's Avatar
DVNCI
Where did you get it?
Old Dec 4, 2007 | 12:14 PM
fc_soldier's Avatar
fc_soldier
Nice deal
Old Dec 4, 2007 | 07:45 PM
DVNCI's Avatar
DVNCI
Originally Posted by fc_soldier
Nice deal
Exactly, $190 is a steal.
To MAF for power!
