Need help with a 4x3 tranny
Old Dec 4, 2007 | 01:15 PM
iceburgh's Avatar
iceburgh
Cruise-In VI Veteran
St. Jude Donor '03-'04-'05-'06-'07-'10
Default Need help with a 4x3 tranny
A buddy of mine just picked up an 85 and called me when it got to his place.
He said it is a 4 speed. I said it was a 4x3 but I have never driven one. so my question is
1. Why is it called 4x3 ( I am assuming 3 gear shave O/D)?
2. How do you switch to O/D
3. He said it wont go in reverse...any ideas?
Old Dec 4, 2007 | 02:08 PM
coupeguy2001's Avatar
coupeguy2001
2021 C4 of the Year - Modified Finalist
Default 4+3
If it is a 4 plus 3, you have overdrive in 2nd, 3rd, and 4th.
I think you push the center of the shifter **** to actuate the overdrive.
some early ones had a overdrive button on the center console I think
Old Dec 4, 2007 | 03:07 PM
XQIZT's Avatar
XQIZT
so much to say...first...do a search on here...look for "4+3", "Doug Nash" or "OD unit" ....those will bring up a ton of threads...
basically is an OD unit mated to a 4 speed manual box...there are 7 forward gear ratios...in order, they are: 1, 2, 2OD, 3, 3OD, 4, 4OD...although i only use the OD in 4th gear over 55mph...
when you say that it won't go into reverse...what exactly do you mean...will the shifter not move into the "reverse" gate or do you mean that you can get the shifter into reverse, but the car won't move?
those are 2 very different problems....
how many miles are on the car...any service records on the transmission?
depending on when his car was manufactured, the OD unit switch is either on the console, rearward on the shifter (next to the power mirror L/R switch) or the actual shift button (like on an automatic) on the top of the shifter is the button...
as a tip...always use the clutch when shifting...even the OD unit...its prolong the eventual failure.
there are plenty here who know plenty about the 4+3...so ask away!
Old Dec 4, 2007 | 03:17 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
4+3 2-4 can be overdriven via switch on shifter console.
Since there is a lack of reverse, I would say there is a good chance the OD unit is toast.
Old Dec 4, 2007 | 04:15 PM
airblaine's Avatar
airblaine
http://www.gearzone.net/43table.htm
this is a great link to find out the characteristics of your year 4+3
Old Dec 4, 2007 | 04:22 PM
XQIZT's Avatar
XQIZT
if the car will shift into reverse and all you hear is grinding and no movement, just pony up for another OD unit...but if you simply can't get it into reverse, it could be a bad linkage adjustment or messed up shift lockout...
Old Dec 4, 2007 | 04:27 PM
USAsOnlyWay's Avatar
USAsOnlyWay
Hmm "4x3", "buddy just bought the car"...
Is there any chance he just isn't pulling up on the shifter to enable engaging reverse?
Oh yeah, and as for 4x3. It came standard on the "Off-Road" package for these guys... Now why would they install that on a Corvette?
Old Dec 4, 2007 | 08:17 PM
iceburgh's Avatar
iceburgh
well I went over after work and showed him what he needs to do. It will go in reverse and move...just does not sound good.
I told hi yank it out and replace with a 5 speed
Old Dec 5, 2007 | 09:52 AM
XQIZT's Avatar
XQIZT
if it grinds once reverse is engaged....yup...OD is shot...bet if you take off the OD fluid pan it'll be filled with clutch material...
as far as a swap...there are other guys around here who know whats easily fits in and what needs to be done...i seem to rmeember there being some concern regarding the 5 speeds...location of shifter or something...the ZF6's go in too with a little modification...but thats not my area...
Old Dec 5, 2007 | 08:24 PM
SurfnSun's Avatar
SurfnSun
St. Jude Donor '10
Tell him to put it in second gear before going to reverse and see if that helps.
Old Dec 6, 2007 | 09:46 PM
FOURSPEEDVETTE's Avatar
FOURSPEEDVETTE
Try pulling up on the little ring just under the shifter ****. It keeps you from shifting into reverse by mistake. Also make sure to go into any forward gear before trying reverse.
To Need help with a 4x3 tranny
