1984 Corvette crossfire injection help?
RACE ON!!!
And as for your criticism of my answering questions and countering criticisms of me, as you express, here, in twisted English:
Give me your address and I'll ship you some capital letters.
RACE ON!!!
I son't usually make smart remarks just when I don't agree with a comment. Like my statement in the last paragraph, ""You are posting blind", isn't because I disagree with you, it is because, you in FACT haven't grasped the subject and your comment, therefore, is OFF subject.
And as for your criticism of my answering questions and countering criticisms of me, as you express, here, in twisted English:Haven't you, in this thread, done EXACTLY what you are yelling me for doing?
RACE ON!!!
What kind of tape did you use, duct tape? I think track officials would prefer to see a fuel pressure gauge tapped into the fuel line, and mounted on the cowl in front of the windshield, but maybe the rules are different where you live?
I would like to try this, but to be honest I am a little uncomfortable using tape to hold a fuel pressure gauge to my windshield.
Jamey, you will need to locate a tee between the tb's. then just extend your gauge up to the winshield. Remember its only temporary. This is how mine is set up.
Nice set up btw.
RACE ON!!!
PS. I just took another look at the pic. My brass T is installed into the stock steel line between the TBs. No special braided hose. The T, flare tubing nuts, and Schrader valve all cost about $12.00, total.
My car ran better with them in but modified slighly. Ran better by meaning it idled smoother and had better response than them out completely. I ran a 14.3@95mph with them out and I had 2" TB's at the same time with the ported intake. I swapped back to stock bored TB's and swirl plates and felt no difference in SOTP and Gtec showed no difference with muliple runs.
For a high 13-14 second car,the swirl plates aren't a problem and either is TB bore size. Similar debate goes with the 1996 LT4 cars and TB size. The underrated LT4's came with a 48mm TB just like a L98 did back in 1985. The LT4's didn't gain much if anything from a larger TB bore diameter and they made a 330chp from the factory. L83's made 205 and don't need more than the stock TB size to run high 13's. I know we are talking about a dry flow system and a wet flow system but the biggest restiction in the CF system lies in the intake runner size all together.
The 14psi fuel pressure everyone say to set it to is a myth to me. I run 12psi and my AFR is mid 11's across the rpm range. Any more fuel pressure and its waaaaaaaay to fat. I've tried 2 different WB02 set-ups and had the same results on both sides of the exhaust. Anything requiring 14psi or higher should have a fuel delivery problem or has a motor that is built to "handle" more fuel demand, i.e; cam,heads,headers,exhaust,etc.
W'regard to fuel pressure, I also agree that adjusting it to arbitrary numbers is folly. You need to "feed your engine what it wants". Every engine is different, and only dyno time or track time (with consistent driving) will reveal what fuel pressure works best for YOUR combo.
MY car was running 15 PSI and a vacuum referenced FPR (~11 PSI at idle) when I sold it, and that's what worked for that engine, but that "data" is meaningless to you, since your combo is different.
-Tom
What's your opinion on modifying the swirl plates?
I would comment on SHINOBI-X's TB bore statement, but that would just spark another 2+ pages of accusations.
RACE ON!!!
