Water pump questions....
Old Dec 8, 2007 | 09:55 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Default Water pump questions....
Since I have everything apart, a new water pump will be put in.....
Here's a question...
Pumps range from $50-$250.
The $250 pump is chromed.
The $50 pump is cast.
I figure I'm looking for a high volume aluminum pump.
Summit has the Wienand for $170.
Questions:
1. Do I need a high volume pump
2. Do I need Aluminum over cast iron?
3. Do I need to spend $170 on a pump?
I'm ready to hit "submit order" on summit for the $170 pump. Just not sure if I should.
Any recommendations?
Thanks.
Old Dec 8, 2007 | 10:49 AM
Aardwolf's Avatar
Aardwolf
I read your thread on Digital Corvettes to, it sounded there like your stock pump was fine. I would just reuse it. I changed the water pump on mine at 100,000 miles and it was not tough. I did not have to take much apart to change it. Get your moneys worth out of it and change it later when it's bad. FYI the Stewart pumps are good and at a nice price.
Old Dec 8, 2007 | 11:17 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
I couldn't justify the extra costs for OEM/high volume/aluminum/chrome.
I got a lot of beer with the money I saved.
Old Dec 8, 2007 | 11:26 AM
redrose's Avatar
redrose
most oem pumps and discount store rebuilds use an impeller that is formed from flat steel and are great for idling at a stoplight with the a/c on...at high rpm that impeller likely cavitates and engine cooling STOPS (this is not desirable for extended periods, but ''might'' be useful for very short duration such as drag racing)
''high performance'' pumps ''should'' (some don't) have an impeller that is a cast, curved blade design...moves more water at all speeds.
prob is that you can't see the impeller without disassembling the pump...look (investigate) before you leap.
''stewart'' pumps work for me.
Old Dec 8, 2007 | 04:45 PM
Corvette Chris's Avatar
Corvette Chris
I'm happy with the Flow-Kooler pump I put on last year.
Brought temps down along with the 180 thermostat.
Old Dec 8, 2007 | 04:46 PM
Corvette Chris
This is the one I put in. Flow Kooler @ Summit
To Water pump questions....
