header tube hitting frame
Old Dec 17, 2007 | 06:57 AM
bob morgan's Avatar
bob morgan
Navigator
Default header tube hitting frame
im installing a set of sw long tube header on my 87. the right side header tube is hitting the frame. any ideas how get it away from the frame. it the 2st tude from the front. please help, i do not what to remove it again.
Old Dec 17, 2007 | 09:28 AM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
On some headers you have to remove material from the frame. Grind it or cut it out.
Old Dec 17, 2007 | 11:41 AM
STL94LT1's Avatar
STL94LT1
Sounds like you may have to dimple that header tube, or do as described above.
Old Dec 17, 2007 | 04:50 PM
86PACER's Avatar
86PACER
Hitting the cross brace? My Hookers hit there. I had to cut off the raised corner part of the brace to clear. Without this, I could not get the header bolt holes to align.
Old Dec 17, 2007 | 06:34 PM
finally_got_it's Avatar
finally_got_it
have you called sw? i just installed some on mine this weekend and there were no fitment issues? But the guys at sw are great to deal with, and probably will have some suggestions.
Old Dec 18, 2007 | 06:07 AM
bob morgan's Avatar
bob morgan
Navigator
thanks for the help. i think i will give a call to sw.
To header tube hitting frame
