87 transmission swap
Old Dec 17, 2007 | 09:08 AM
Russ Dreikorn's Avatar
Russ Dreikorn
Default 87 transmission swap
Will the zf 6 speed from the later C4 drop in a 87? I have an auto and wish to change to a std. Will the bellhousing for the zf mate up with the early L98? or do I need a bell housing for a 4-3 which came stock in the car? Is the drive shaft different for the ZF?
Old Dec 17, 2007 | 10:32 AM
bogus's Avatar
bogus
Yes. Search for CentralCoaster. He has all of this documented.
Old Dec 17, 2007 | 02:56 PM
skybolt31's Avatar
skybolt31
check out this thread, lots of great information on available swaps for early C4's
http://forums.corvetteforum.com/show....php?t=1662863
Old Dec 17, 2007 | 03:30 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
No that thread pretty much turned into a T5 swap thread.
If you're considering ZF try this thread:
http://forums.corvetteforum.com/show....php?t=1805179
Cost of my swap was ~$1600, but I later did gears too, for another $400.
Your other options are:
TKO (classicchevy5speed or keisler)
T5 (work in progress by anesthes)
Richmond 6-speed ()
Old Dec 17, 2007 | 08:54 PM
AKS Racing's Avatar
AKS Racing
I converted my '87 to ZF and have done several other Auto to ZF conversions. Either ZF trans (blue or black tag) will bolt in the early C4. Requires bellhousing (bolts right up to all L98 blocks), driveshaft, ladder and most all other parts from a ZF equipped car. Including positive battery cable, starter, dust shield, trans tunnel hump, etc.
At that point, you may be better off just buying a ZF vette. It is quite a bit of work.
Aaron
To 87 transmission swap
