Header blankets vs wrap
Old Dec 20, 2007 | 10:21 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Default Header blankets vs wrap
I really want to keep the heat down under the hood of my car with the blower install.
I am going to thermal wrap the headers, but not the way most do.
I want to do it this way
Not this way
http://www.streetperformance.com/pro...ompany_id=1043
That way there's less surface area exposed, and less places to trap things like oil.
I think if I do it right, I can also install/remove it while the headers are installed in case I need to work on anything.
Thoughts?
Old Dec 20, 2007 | 11:20 AM
ToniH's Avatar
ToniH
You do have some kind of heat blocking coating on the headers, right?
Can't say anything about the blanket but on the subject of keeping the heat down under hood: have you considered letting the heat out instead of trapping it inside the engine compartment? I mean louvers of some kind. Like the functional Greenwood hood louvers or something similar?
BTW. like you said you need to be able to remove the blanket easily as there is no access to plugs with it.
Old Dec 20, 2007 | 11:23 AM
cv67's Avatar
cv67
St. Jude Donor '05
I would think a good coating would be sufficent, but being as boost creates more heat maybe the blanket idea would help. Not a big fan of wrap because of concerns with soaking up oil. I think youll find youll love the coating.
Old Dec 20, 2007 | 11:24 AM
KeyWestJack's Avatar
KeyWestJack
I agree with ToniH. Just a thought but with the blanket I might be concerned about accumulation of heat.
Old Dec 20, 2007 | 11:31 AM
ToniH's Avatar
ToniH
BTW. if the heat wrap is cloth type which is more likely to soak up oil, like the 2nd type in Brian's pictures, you can paint the wrap with fire proof paint. The paint seals up the cloth so oil does not absorb into it so easily.
Old Dec 20, 2007 | 11:59 AM
BrianCunningham
I hoping to keep the heat in the exhaust which will then exit the car.
I've also seen formula cars where they run cooling ducts to chambers created by the wrap. Kinda like a heat stove in reverse.
As far as venting the hood, that's in the works. Though the nice thing about the Vortec is that it fits under the stocker.
Old Dec 20, 2007 | 12:04 PM
comp's Avatar
comp
wrap and blanket,,,,,do the vents to
Old Dec 20, 2007 | 12:16 PM
ToniH's Avatar
ToniH
That will never be 100% effective so venting out of the hood is a good idea and will compliment the header wrap/blanket. I don't mean a special hood but actually cutting the existing one to let heat out.
I bought the Greenwood louvers and I think they do the job nicely when installed. Looks nicer too than just cutting it
Old Dec 20, 2007 | 12:20 PM
BrianCunningham
That's actually the kit I had in mind.
I'm going to check out Mr.Magoo's car when I get back to NE
No toast
Old Dec 20, 2007 | 04:36 PM
BrianCunningham
Chevy's solution on the new ZR-1
Old Dec 20, 2007 | 05:05 PM
ToniH's Avatar
ToniH
Pretty much the same idea they used in L98 Vettes but a nicer realisation. L98's also had stainless shorty headers with heat shields. Later C4's for some reason got the cast header solution
Old Dec 20, 2007 | 06:51 PM
bill mcdonald's Avatar
bill mcdonald
every pic of the stock viper rt-10 seems to have the foil wrap.
I think the second wrap is great, having it on my car.
just be careful with the oil. I learned a few lessons.
Old Dec 20, 2007 | 08:56 PM
metal tech's Avatar
metal tech
If you get a chance call the people at Swain Technologies http://www.swaintech.com/. They have some coatings that work very well on headers & other Hot Section parts. With a good coating you don't have to worry about oil soaking into a fiber/cloth type material and the added fire risk.
Old Dec 20, 2007 | 09:36 PM
cv67's Avatar
cv67
St. Jude Donor '05
Do some of those headers tubes look crimped as they come out of the head or are my eyes that bad?
Old Dec 22, 2007 | 07:26 PM
5abivt's Avatar
5abivt
They are D shaped for better and faster flow
Old Dec 22, 2007 | 09:06 PM
Trog's Avatar
Trog
I used to use the header wrap on my old V8 Vega, it was a foot cooker. But I also remember reading somewhere later on that wrapping header tubes close to the head traps too much heat & caused uncoated headers to crack from heat fatigue.
YMMV...
Old Dec 22, 2007 | 10:32 PM
LTxDave's Avatar
LTxDave
If your headers are coated, I'm pretty sure wrapping them will void the warranty and make the headers deteriorate quicker.
Old Dec 23, 2007 | 03:31 PM
BrianCunningham
BTW They are coated.
I just unwrapped the EM LT's today.
The quality of the jet coating is amazing, they looked like they were chromed
Gaskets and hardware came with it
Old Dec 23, 2007 | 07:05 PM
cv67's Avatar
cv67
St. Jude Donor '05
Sweet! Nice short collector too.
So which side of the bed were those on last night?
To Header blankets vs wrap
