new 4 bolt roller engine project
Old Dec 23, 2007 | 06:46 PM
Deakins's Avatar
Deakins
Shea we would run a set of total seal, max seal gapless rings in this engine. All the high performance engines out there have filed to fit rings and that is really the way to go. The information you need when you order the rings is this; the final bore size (4.030, 4.060 whatever it ends up being), and the ring groove sizes. The first you will get from the machine shop and the second will be stated from the piston manufacturer. We have used these rings without problems and recommend then in most applications. The rings are available in sets from many mail order outfits.
Old Dec 23, 2007 | 07:11 PM
emo-vet's Avatar
emo-vet
hi pete k and deakins,
ok thanks for your help and reply r.e what rings i need to buy!
so now i can search on what to buy now.
cheers
shae
