AFR Head Users---Question 4 U
Old Dec 26, 2007 | 09:12 PM
LTxDave's Avatar
LTxDave
Default AFR Head Users---Question 4 U
What valve covers are you using? I am running LT4 210's (or trying to!) for my 383 and ran into a problem with my die cast moroso valve covers. I did some grinding on what WAS holding the covers off from seating and realized that now the hold up appears to be the polylocks. I'm running 7/16" studs and comp cams promagnums with polylocks. Anyone have a similar setup and a valve cover that works?
Old Dec 26, 2007 | 10:14 PM
FD2BLK's Avatar
FD2BLK
I have the 195's (Same casting as yours) and am using my stock covers, just trimmed up a bit because of the lip you already know about. I also have ran a set of covers I got off ebay that I hat to cut the supports out of that may be closer to what you have.
Here is couple of shots of the mods I did to the old covers
Here is a good shot of the motor with the AFR's and Pro Mags w/ 716 studs
Old Dec 26, 2007 | 10:35 PM
pablocruise's Avatar
pablocruise
I used a "tall" v/c.
Same head, valve-train as you.
I had no prob with the wiper motor.
Old Dec 26, 2007 | 11:28 PM
FD2BLK's Avatar
FD2BLK
Just a word of caution I almost forgot about. The alternator will hit the drivers side V/C unless it is notched, ask me how I know. I was able to modify my old alt. just enough to clear but I cant see you ever being able to use a taller set of covers without the notch. I had already switched back to the stockers before my alternator was replaced so it completely slipped my mind
Old Dec 27, 2007 | 09:36 AM
LTxDave's Avatar
LTxDave
Did you have to do any clearancing on the factory covers?
I thought about running an old style tall cover, but after looking at the alternator and bracket, I realized it was not really an option.
Old Dec 27, 2007 | 11:33 AM
FD2BLK's Avatar
FD2BLK
[QUOTE=Mr Dave;1563334079]Did you have to do any clearancing on the factory covers?
QUOTE]
Just removing the drip tabs and trimming the inner lip so they would seat onto the AFR's
Old Dec 27, 2007 | 04:31 PM
emo-vet's Avatar
emo-vet
hi fd2blk,
how are ya!
soory to but in guys !
i have brought a set of finned top edelbrock valve covers and will also be buying start next year some afr ported comp heads.
you mentioned a inner lip on covers, where on the picture you kindly provided is this lip please ???
also where you have ground down inside trib tabs i belive,
do you also grind slightly each side where the centre bolts come thru as well on each side or one side do you please ???
can you use a angle grinder with a cutting wheel to grind this stuff down ??
lastly i noticed that you ground down one side more than the other,is that rite please ??
i hope you can help me out with these questions please !
thanks very much
cheers
shae
To AFR Head Users---Question 4 U
